Old 06-02-2015, 06:20 AM   #1
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
Water Leak
Develop a major leak under table booth. Water coming out of the rear of booth chair near refrigerator, especially when water pump on. Currently draining all fresh water from Airstream, flushing the lines, and taking to dealer for warranty. Bummer, my favorite Rally 4CU Santa FE Skies this week end and will miss it. I am sure table booth bench seat needs to be removed.I want to do it, but sure warranty work must be completed where I bought it, since it is within 100 miles from me. Things just keep breaking, I guess that is why there is a two year testing ground.
Luigi123 is offline   Reply With Quote
Old 06-02-2015, 06:24 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The 100 mile rule? Never heard that.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 06-02-2015, 09:10 PM   #3
Luigi123's Avatar
That should have read,"but sure warranty work should be done by dealer which is only 100 miles from our home."
Old 06-02-2015, 09:36 PM   #4
Plasma800's Avatar
houston , Texas
Broken pipe?
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 06-03-2015, 06:04 AM   #5
Luigi123's Avatar
Dropped off at dealer, in which they will strive to get me on the road ASAP. I only posted this in hopes someone MAY HAVE had a similar situation in the area of Airstream and could possibly alert me to the problem and their fix. At this time, it appears booth/bench seat will need to be removed, not sure the down time and parts from factory that maybe needed, but will post the fix involved so to assist anyone with similar issue--which I hope this is an isolated issue in the year and model.
Old 06-03-2015, 06:51 AM   #6
2014 28' International
San Jose , California
Water leak
We have a similar problem with a small water leak that was unnoticeable to us that over a period a of few weeks damaged the flloor by the kitchen area, first we noticed a very small bump that over time got bigger and got soo bad that we have no idea what caused it. Since we had to take our trailer to the dealer for the recall of the propane tanks fix we asked them to look to the floor problem.This turned into a major problem since they have never seen a floor with a bump like that, first they thought it was a structural problem but after further inspection from the bottom of the trailer they detected a water leak running over one of the structural frames of the chassis. As I am writting this note, we don't know the origin of of the water leak yet but hopefully today they will find it. For sure the water running over the frame was the culprit. Like you we drove about 700 miles to get back to our dealer. Our rig is a Intl 28, 2014
Flyingsilver is offline   Reply With Quote
Old 06-03-2015, 09:39 PM   #7
Luigi123's Avatar
Thanks Flyingsilver, I will update my posts when the fix is in place.
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
