Old 03-07-2014, 11:38 AM   #1
2005 28' Safari
Challis , Idaho
Water leak
I have a 05 safari. My water hose froze and broke my regulator. I replaced that and checked on the inside under bathroom sink for leaks and was pleased to find everything dry. Woke the next morning to find a wet spot on my carpet where the linoleum meets by my bed. Trying to figure out the best way to find the leak.
Tswain is offline   Reply With Quote
Old 03-07-2014, 02:10 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
To make sure it is not from the original leak, cap or use a shutoff on your site water inlet and turn on your water pump. If it cycles, you have a leak. If not, water probably from original leak.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-10-2014, 10:50 AM   #3
2005 28' Safari
Challis , Idaho
I definitely have a leak. It only shows up in one spot on the carpet when under pressure. Between the bathroom and closet. Pump won't shut off. Now just wondering if it's better to try to get to it from above or bellow
full water system rebuild geoff evans Fresh Water Systems 9 01-02-2012 10:10 AM
Help-dewinterizing and no water off freshwater tank bonginator Water Heaters, Filters & Pumps 6 06-12-2011 08:37 PM
Water supply question at a state park. meadowlm General Repair Forum 6 06-07-2011 10:57 PM
Grey water...where does it go? KyMoonshine Plumbing - Systems & Fixtures 10 03-21-2011 04:12 PM
