Old 01-21-2010, 11:04 AM   #15
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
That's exactly what I need to get.I will look for that for sure.the brass fitting is well worth theoney and extra work than having that cheap plastic on it.
Oh...I sent you a P.M. 1Air.thanks
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 01-26-2010, 02:05 PM   #16
Devoman's Avatar
Airstream
Just called Airstream a while ago and it seems that all unit whether the base model to the most largest Airstream uses the standard shurflow city water connect.They told me that I could just purchase one without the regulator on it and then add one myself but I think I will just order the same OEM one that has always been used.I just had been the lucky one to get 2 that messed up.
For all I know I could have tightened it up just enough to put a small hairline crack in it and it finally popped.Who knows.I will have it fixed once it comes in the mail.
Old 01-26-2010, 02:18 PM   #17
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Hey Devoman, sorry you are having problems. I had the same thing happen with mine. When you get your new one in, you can test it before you install it. Just buy a threaded end cap, screw it on and hook up the water. If it is bad, it will leak. If no leak, install.
I did a thread on this back last July. If I knew how to insert the link, I would.
Hope all is well out your way. Looks like they'll be another invasion labor day!
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 01-26-2010, 04:27 PM   #18
MsRivet's Avatar
2004 28' International CCD
1948 22' Liner
Oakland , Florida
Send a message via Yahoo to MsRivet
Welcome to the club. We've replaced ours twice in just under three years. Our thinking is that the first one we installed was faulty. So far the second one is holding up. But at least now we know what to look for and have the gadgets to get the job done.
MsRivet is offline   Reply With Quote
Sewer Hose Connector Diana Langley Waste Systems, Tanks & Totes 25 08-12-2006 08:12 PM
broken water hose connector ylander Plumbing - Systems & Fixtures 0 06-09-2004 04:27 PM
dump hose connector Tin Hut Waste Systems, Tanks & Totes 5 10-11-2003 08:25 PM
Connector Diagram at AIRSTREAM smily Brakes & Brake Controllers 0 09-10-2002 08:02 AM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 12:48 PM
