Old 07-21-2008, 09:05 PM   #1
Water flow stopped suddenly
Water flow suddenly stopped for no apparent reason in my 2004 airstream bambi. I am using city water with no regulator on the hose. It is my understanding there is a regulator on the other side of the wall where the hose connects to the trailer. I disconnected the hose and used the water from the inside storage tank for a day, then reconnected the hose and it was fine. Then two days later, for no reason, it stopped suddenly again. Any ideas as to what is happening?
dryan is offline   Reply With Quote
Old 07-21-2008, 09:20 PM   #2
cameront120's Avatar
1972 25' Tradewind
Unreliable city water? City water pressure can be variable. This is why we use pressure regulators. During peak usage times water pressure can drop quite considerably.
North Vancouver, BC
Old 07-21-2008, 09:27 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
You could have a defective regulator and/or check valve. If it's the check valve, it is sticking closed and not allowing the water to flow thru. The regulator could possibly do the same thing.
If you can access these components (they are usually in-line with each other), you can disconnect them and then flow the city water right thru the connection to see if you are getting any water. If you're worried about excess pressure in the line, you can use a regulator right at the hose bib connection.
Old 08-24-2008, 06:55 PM   #4
I removed the regulator that is built into the side of my airstream and replaced it with an identical one that was white plastic as opposed to the plastic covered with silver paint model that came with the trailer. That solved the immediate problem of NO water. But this regulator is almost TOO efficient. Are regulators available on the market that can be adjusted? I'd really like to have a bit more shower pressure when I bathe. This one cuts the pressure back such that it is like using the onboard water pump. The water pressure is pretty limp, in equal measure, at the kitchen sink, the bathroom sink, shower and toilet.
Old 08-24-2008, 07:06 PM   #5
1994 30' Excella
Mississauga , Ontario
On the issue of pressure regulators everyone should realize that some parks have very high water pressure. Therefore it may be a good idea to use a pressure regulator right at the park faucet to protect your hose from unusually high pressure.
Obviously a pressure regulator will influence the water flow somewhat.
Al
Old 08-24-2008, 09:11 PM   #6
1972 25' Tradewind
Watts may make one.
North Vancouver, BC
Old 08-24-2008, 09:51 PM   #7
lewster's Avatar
There are several adjustable water pressure regulators available, but the all connect via the hose, and should usually be placed right at the hose bib to protect your hose from excessive pressure, as well as your trailer.
Valterra recently came out with a really nice adjustable model...#AO1-1116VP. Marshall and Camco also have them available.
Old 08-25-2008, 06:25 AM   #8
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Adjustable Water Pressure Regulator
I don't know when Airstream discontinued the use of the brass adjustable water pressure regulators, but my '64 Overlander still has its original adjustable water pressure regulator mounted as the first device on the incoming water line. The one in my overlander looks similar to the one below:
Grainger handles these valves, and the link to these valves can be found at: water pressure regulators.
I may end up ordering one of these for my Minuet. On my last trip out, my city water quit working, and I suspect that the original valve may have become clogged with minerals over the past thirty years.
Kevin
Kevin D. Allen
AIR #827
How do you clear a stopped up black water tank? Aluminumb Waste Systems, Tanks & Totes 9 10-26-2007 12:11 PM
city water won't flow..help! AirSpleen Fresh Water Systems 9 08-20-2006 05:39 PM
Suddenly I'm 60 !!!!! CruiserBob Off Topic Forum 11 01-05-2006 06:02 PM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
