Old 02-27-2016, 04:34 PM   #1
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
Water Flow Problem
2016 Flying Cloud
I turn pump on and pressure does not seem very good compared to past trailer I owned. I verified flow at 1 gallon at 1.5 minutes from the cold side faucet.
Seems low and it takes 10-12 seconds to rebuild pressure. I have verified all connections. The pump is rated at 3 gallons a minute. Could someone verify what their flow rate is?
mcomeaux is offline   Reply With Quote
Old 02-27-2016, 04:51 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Sounds like a loose connection in the system causing the pump to suck in air before drawing water.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 03-01-2016, 09:39 PM   #3
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
The facet can be restricted. Perhaps with construction materials. Try taking the aerator off, it has a restriction in it, or running two facets at the same time.
My trailer had a long run time to reach maximum pressure when it was plumbed with the gray tubing, 5-8 seconds.
sgschwend is offline   Reply With Quote
Old 03-02-2016, 05:42 AM   #4
mcomeaux's Avatar
Sunriver , Oregon
Update: As it turned out they removed nozzles and cleaned debris from construction and now I have great pressure and quick recovery.
Old 03-09-2016, 02:10 PM   #5
1962 16' Bambi
Pendleton , Oregon
I have a 1989 Safari, 25 ft. As the water turns hot the flow drops from reasonable to a trickle. This is true for hand bowl, sink and shower. Before the water turns hot the flow is normal as is the cold at all times. The previous owner told me about the problem prior to my purchase. He replaced the water heater and the kitchen faucet which work fine, other than the flow problem.
any ideas?
62BAMBI is offline   Reply With Quote
Old 03-09-2016, 08:10 PM   #6
1999 30' Excella 1000
small town , Maryland
62BAMBI Check the washers on the hot water tank bypass valves. My washers were stuck on the seat of the valve. I had good cold pressure and 25% hot pressure, before I figured it out. Hope this helps. streaminwild
streaminwild is offline   Reply With Quote
No water flow after hooking to city water Grevers911 Fresh Water Systems 8 06-23-2013 10:08 PM
Here's the problem, what's the diagnosis: propane flow eubank LP Gas, Piping, Tanks & Regulators 23 09-12-2012 08:25 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
