Old 05-11-2019, 04:58 PM   #1
2017 28' International
Baileys Harbor , Wisconsin
Water Filters
What are the best water filters to filter water from the water source to the AS? At home we have filters that we use to drink from. But they are low pressure, and are installed under the sink. I want that water filtered before it gets to the other fixtures as well. Sediment destroys fixtures. The one we use now I just bought from Walmart and is a standard filter. But I would be interested in any recommendations.
Daquenzer is offline   Reply With Quote
Old 05-11-2019, 06:17 PM   #2
SewStream's Avatar
Sanford , Arizona
Water Filters
We use a ClearSource (exterior) two stage filter for the city water hookup and to fill the fresh water tank. We then filter our drinking water with a Berkey Filter - Travel Berkey.
https://www.clearsourcerv.com/
SewStream is offline   Reply With Quote
Old 05-13-2019, 09:18 AM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we have two high flow filters
1st a cloth filter
2nd a carbon filter
waninae39 is offline   Reply With Quote
Old 05-13-2019, 09:25 AM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
here is what our filters look
http://www.airforums.com/forums/f445...er-194846.html
Old 05-13-2019, 09:58 AM   #5
2019 30' Classic
Belen , New Mexico
We use this one from Clearsource for connecting to city water and/or filling the freshwater tank. They are full flow, solid block carbon filters.
The water is technically good enough to drink from at that point, but I'm installing this RO water filter under the sink this week. We like using RO water for drinking and cooking.
Ephraim is offline   Reply With Quote
Old 05-13-2019, 07:59 PM   #6
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
FWIW, I worked in the water treatment field for 10 years before leaving to travel full time a couple of years ago, so I have some fairly strong opinions about what I do with my own water. But not everyone will have the same needs as me. How you are using your trailer and what your concerns are might lead you to make different choices.
I soften all the water I put in my tanks with an RV water softener, and I add chlorine to the fresh tank at every fill up. I remove the chlorine and any cysts with a high flow carbon block directly after my water pump. I also use a zerowater pitcher for drinking.
TheGreatleys is offline   Reply With Quote
Old 05-13-2019, 08:18 PM   #7
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
I installed an internal version of ClearSource after the city water intake under our rear twin. As others indicated, itís full flow.
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 05-13-2019, 08:32 PM   #8
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this is my main AS filter set
plus the triple one just for drinking water
Name:	dual high flow water filter-apr2019.jpg
ID:	340678   Click image for larger version
Name:	triple flilter for seperate sink tap- drinking only.jpg
Name:	whole trailer filter.jpg
Old 05-13-2019, 08:36 PM   #9
1974 27' Overlander
Attachment 340674
That thing is looking like $275 from Amazon, is that right, or is it cheaper elsewhere?
If you're interested in this system but up for very slightly more DIY:
https://www.amazon.com/Pentek-10-Sta.../dp/B003VT7ERY
2 Housings @ $26.22/ea
https://www.amazon.com/Pentek-150578.../dp/B004VNCFWI
2 Brackets @ $7.74/ea
https://www.amazon.com/Pentek-SW-2-S.../dp/B003VT5GCE
1 Wrench @ $5.06
https://www.amazon.com/Pentek-String.../dp/B0014BY2GM
1 sediment cartridge 5 micron $6.79
https://www.amazon.com/Pentek-FloPlu.../dp/B003ZVZ79U
1 high flow carbon block 0.5 micron $15.72
$95.49 all in
Old 05-13-2019, 10:58 PM   #10
2016 19' Flying Cloud
Miami Springs , Florida
We camp mostly at State Parks and isolated areas in Florida, places where water is typically good, but I am afraid that campground pipe networks aren’t. We use the popular Camco filter more as way to protect the RV, but we drink bottle water. The Clear Source option seems really interesting, does it really take away funny flavors?
Gallego is online now   Reply With Quote
Old 05-14-2019, 09:25 AM   #11
1974 27' Overlander
Originally Posted by Gallego View Post
We camp mostly at State Parks and isolated areas in Florida, places where water is typically good, but I am afraid that campground pipe networks arenít. We use the popular Camco filter more as way to protect the RV, but we drink bottle water. The Clear Source option seems really interesting, does it really take away funny flavors?
Any carbon filter will reduce most off-flavors and odors. The most common exception would be hydrogen sulfide (rotten egg/sewage type odor found in some wells), which carbon filters don't do much for, but a little bleach in your tank will correct entirely.
Old 05-14-2019, 10:10 PM   #12
We always connect to city water, we have never used the tank
Old 05-15-2019, 05:13 AM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
We use a Camco filter at the water source and when filling the tank.
You most likely have another filter under the sink that filters the cold water there.
When boonbocking where there is a water source (like a hand pump) we fill a Brita filter pitcher to use for cooking and drinking, thus saving tank water for showers.
2012 Dodge Durango Hemi/AWD
Old 05-19-2019, 08:02 AM   #14
Sometime , Alabama
TheGreatleys...
...please let me know what bleach to water ratio that you use.
Thanks.
bigcountry is offline   Reply With Quote
Question about Water Filters in the Classic time2play 2011 - 2015 Classic (all lengths) 10 02-24-2015 04:48 PM
Water filters, winter system draining and etc. malconium Water Heaters, Filters & Pumps 1 12-31-2009 08:18 PM
Water filters system by SEARS brunoffrance Water Heaters, Filters & Pumps 9 06-09-2008 03:24 PM
Water filters in Classics ralley Classic Motorhomes 5 08-10-2007 12:03 PM
Ogden water purifier filters scottanlily Water Heaters, Filters & Pumps 7 11-15-2006 09:02 PM
