Old 07-31-2012, 08:17 AM   #1
treeair's Avatar
1971 23' Safari
Bozeman , Montana
Water damage
We've been using our '70 Landyaht as our kitchen /bath while we remodel the house this summer. It was the first time I had hooked up to city water. I was concerned about the hobbled together plumbing holding up to constant pressure at turned off water supply most nights. Forgot last night and prepared my coffee standing on soggy carpet. Small leak in one of the rubber hoses. Damn.
Got the carpet and pad ripped out and water looks mostly confined to kitchen area. I figure the insulation in floor is soaked. What are the options to dry that out? Pretty hard to find the time to drop the pan since I'm just getting going on the house. Any thoughts? Thanks for your help.
On the plus side we had wanted to rip out the nasty shag since we got the trailer so at least we get a new floor out of the deal.
treeair is offline   Reply With Quote
Old 07-31-2012, 09:16 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If you could drop a 3' section or just open the side a hair. You could then run a fan. Any air moving through there would help dry it out.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
