Old 05-31-2014, 10:50 AM   #1
1976 25' Tradewind
1959 22' Flying Cloud
Mineral , Virginia
Water coming out of inlet port on trailer?!
I installed a new water pump in my trailer today because I could not get the original pump to pump water. We put water in the fresh water tank for this process. No hose is connected to the inlet port on the left rear of the trailer where I think that the city water connection would be. I think that I connected the hoses yo the pump correctly. I flipped the pump switch and now receive water to the kitchen sink as well as to the bathroom sink. The problem is that water is bring pumped out of the inlet port where you would connect the water hose for city water. Did I do something wrong, of is there a valve that had gone bad at the inlet port? Or.....?? Please help! Thanks in advance!
Mrhany is offline   Reply With Quote
Old 05-31-2014, 11:20 AM   #2
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Sounds like you need a check valve on the rear city fill line.
goshawks00 is offline   Reply With Quote
Old 05-31-2014, 03:29 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Clean out the outlet from the inside! Little bits of crap get caught in the check valve and allow leaking. I use those washers with the integral screen to keep junk out of the plumbing.
Just screw off the back, you'll see how easy it is!
Inlet port on the water pump for 2012 FC urnmor Winterizing, Storage, Carports & Covers 23 11-28-2013 09:16 AM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 08:57 AM
Water coming out city water inlet mutcth Fresh Water Systems 5 05-27-2011 09:23 AM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 03:07 PM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
