Old 06-18-2018, 06:30 PM   #1
1989 29' Excella
kiowa , Colorado
Water coming out of city water outside hookup after I turn on my pump
I filled my fresh water tank using the potable water fill up and water is coming out of city water outside hookup after I turn on my pump. I have an 1989 excella and don't have anything at the city water hookup that is a regulator unless it is built in. It comes in and has the normal drop valve for draining and then goes to pump T and into the rest of the system. There is a filter on the pump and after the pump another inline filter and a very large filter under the sink.
I took out the pump and looked at the check valve in the front of the pump and it felt stuck. Nothing in it and don't know what the white valve is supposed to do. Is this supposed to come out or pop out when the pump is off and close off the water coming through the pump?
Also should I put in a back flow prevent er after the city water hookup? If I need one should I get another pressure regulator in line on the city water hookup?
Joeb is offline   Reply With Quote
Old 06-18-2018, 07:34 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The city water fill should also have a check valve. Removal of 4 screws on the backside will allow access to the guts. From there you can check for mineral build up and other crud. I once had a diaphragm tear, maybe from an accidental freeze.
A replacement unit can be had for about $39 online. Takes 5 minutes to replace.
Old 06-18-2018, 08:00 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Look in your Owners Manual in the plumbing section F. There is a diagram of the fresh water plumbing. You should see a check valve near the city water inlet. If water is coming out the city water inlet, that check valve has failed or possibly has trash in the valve itself keeping it open. By hooking up the city water and flushing it out you might fix the problem.
add edit:
If you do not have a manual, this is a web link where you can download a copy:
https://www.airstream.com/wp-content...LY-Trailer.pdf
Alan
Old 06-19-2018, 09:48 AM   #4
1989 29' Excella
kiowa , Colorado
Don't have anything
Hi and thanks for the info. I don't have anything at my city water hookup. No regulator or check valve. It comes in and goes directly to my pump with a T going to the drain and that's it.
Please send a link on what I should have if anyone has it on the regulator and check valve.
Old 06-19-2018, 05:08 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
If it is plumbed as you say, it is not original.
Post a photo of what you have.
add edit:
could be something as small as this if inline
https://www.vintagetrailersupply.com...-p/vts-725.htm
Or
could be part of the inlet itself (this one is chrome, but there is a white plastic older version
http://airstreamsupply.com/index.php...ch=check+valve
Or
There is another type inlet, similar to above, with the check valve and pressure regulator all in one device.
Alan
Old 06-19-2018, 05:51 PM   #6
1989 29' Excella
kiowa , Colorado
Hard to photograph
Its hard to get a good photo of it but it is a white outside with a inside brass piece and I am sure that it has the regulator but no check valve. I will add another regulator on it that I can adjust and also get the check valve next and that should do it. Then unto leaks from it not being correct I am sure that will happen.
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
No Water coming out of outside show nozzle after de-winterizing bonginator Winterizing, Storage, Carports & Covers 0 05-26-2012 08:24 PM
Water coming out city water inlet mutcth Fresh Water Systems 5 05-27-2011 09:23 AM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 03:07 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
