Originally Posted by Joeb
I filled my fresh water tank using the potable water fill up and water is coming out of city water outside hookup after I turn on my pump. I have an 1989 excella and don't have anything at the city water hookup that is a regulator unless it is built in. It comes in and has the normal drop valve for draining and then goes to pump T and into the rest of the system. There is a filter on the pump and after the pump another inline filter and a very large filter under the sink.
I took out the pump and looked at the check valve in the front of the pump and it felt stuck. Nothing in it and don't know what the white valve is supposed to do. Is this supposed to come out or pop out when the pump is off and close off the water coming through the pump?
Also should I put in a back flow prevent er after the city water hookup? If I need one should I get another pressure regulator in line on the city water hookup?
Look in your Owners Manual in the plumbing section F. There is a diagram of the fresh water plumbing. You should see a check valve near the city water inlet. If water is coming out the city water inlet, that check valve has failed or possibly has trash in the valve itself keeping it open. By hooking up the city water and flushing it out you might fix the problem.
add edit:
If you do not have a manual, this is a web link where you can download a copy:
https://www.airstream.com/wp-content...LY-Trailer.pdf
