Old 05-23-2014, 02:03 AM   #1
1981 31' Excella II
Rye , East Sussex
Waste water connection
I've recently bought a 1981 Excella II 31footer and need to connect the waste, grey water to a hose to drain away. I have a Valterra termination cap fitted to the outlet on the Airstream. The cap has a small inset screw cap to accommodate the hose, so I need a simple connector to join them. The only problem is that I'm in the U.K. and our plumbing threads are differwent to U.S ones. Perhaps any U.S. hardware store would have what I need - can anyone help please?
Regards - Geoff, backtrackrye
backtrackrye is offline   Reply With Quote
Old 05-23-2014, 04:04 AM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
This female repair part just pushes in and then the hose clamp retains it.
This one is cheaper and won't last as long, but I like this type because it doesn't have that excess band of steel that sticks out from the tightened hose clamp, which can bite you as you attach the hose.
I just Googled "garden hose female repair," but the geographic filter in Google might not direct you to USA parts.
Zep
City Water Connection R&SZinser Fresh Water Systems 14 08-20-2012 05:30 PM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
Thetford Valve Connection to waste piping 77Overlander Waste Systems, Tanks & Totes 2 11-04-2009 08:27 PM
Water connection. Theo Fresh Water Systems 5 01-15-2004 03:09 PM
New City Water Connection j54mark Fresh Water Systems 5 07-01-2002 07:03 AM
