Old 09-27-2018, 03:43 PM   #1
tracker
tracker's Avatar
1969 23' Safari
crescent city , California
vanity backing up
my 69 safari has started to back up or drain into the tub is this common on A/S that don't have a greywater tank?
tracker is offline   Reply With Quote
Old 09-27-2018, 05:57 PM   #2
Retired.
. , At Large
If there is no grey tank, where is the water draining?
Old 09-27-2018, 06:35 PM   #3
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
What have you been doing for the past 14 years?
IIRC 69s had no Grey Tank unless you've added one. In that era grey water drained to the ground and it was up to you to route it where you wanted it with a hose.
The Ice Man is offline   Reply With Quote
Old 09-27-2018, 06:35 PM   #4
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
As a former owner of a plumbing drain cleaning franchise, let me explain what is happening. Its the same thing that happens in a house.
There is a restriction of the flow into your black tank (septic tank or city sewer). When the vanity is draining, it is at a higher elevation than the tub. The rushing water hits the restriction then backs up into the least resistance, which is the tub because it is at the lowest elevation before the restriction. When your main sewer line starts backing up, the first place you will notice it is in your tub.
We used to sell a product called Bio-clean. It would eat away at that restriction without hurting the plastic pipes. Do not use draino or liquid plumber as these products can melt plastic pipes. You want to use something that is bio-degradable, not chlorine based. Here is an amazon link to the Bio-clean product: https://www.amazon.com/Bio-clean-Dra.../dp/B001N09KN4
Yes, we too sold it for $40 to $50, and there was a nice "margin" in that price. I will say that this stuff did work better than any other product we tested. The results are not immediate, you need repeated applications as per the instructions. But eventually, it should clear the restriction.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 09-27-2018, 07:42 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The water is backing up in to the tub because you have the termination cap on the sewer dump. You have no "grey water holding tank". Thus no where for grey water to go other than in the shower.
If you remove the sewer cap the grey water will drain.
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 10 01-05-2010 06:30 AM
'69 bathroom vanity lights goransons 1959-69 Tradewind 14 08-29-2007 08:22 PM
Anybody Need gaucho and vanity? bilby05 Cabinets, Counter Tops & Furnishings 6 06-26-2007 02:58 PM
Vanity mirror catches searcher 2000 - 2004 Safari 1 05-06-2007 08:54 AM
Vanity License Plate Ideas FordTruck On The Road... 7 01-06-2007 06:03 PM
