Old 05-29-2004, 04:42 AM   #1
frederic.c01's Avatar
1973 23' Safari
amberieu en bugey France , france
Images: 69
Send a message via MSN to frederic.c01
valves with photos
hello
can one say to me what serve these valves and D .
there function to have the pressure for the tap with pump water.
thank you for your assistance
frederic.c01 is offline   Reply With Quote
Old 05-29-2004, 04:59 AM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Frederic.c01;
No photos are attached.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 05-29-2004, 12:56 PM   #3
1973 23' Safari
Images: 69
Talking valves again
sorry for the photos I had to forget!!!!
what serve the valves A B C and what D ?
Old 05-29-2004, 11:57 PM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
B and C look like the hot and cold water drain lines used for winterizing.
A is probably the drain for the fresh water tank.
I cannot tell what D is....
-Tim
theVAP - Airstream Podcast
Old 05-30-2004, 12:52 AM   #5
upallnight's Avatar
It looks as if D is some sort of water softener or filter.
Leonard
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 05-30-2004, 04:21 PM   #6
frydmans's Avatar
1971 27' Overlander
Mequon , Wisconsin
I have 2 valves in the rear compartment below the battery in my "new" 1971 27' international. Any idea what they control. Thanks
Steve
frydmans is offline   Reply With Quote
Old 05-30-2004, 04:54 PM   #7
D is most assuredly the water filter.
any help would be....ah.....most helpful!
joecj76 is offline   Reply With Quote
Old 06-02-2004, 02:17 PM   #8
1973 23' Safari
Images: 69
Talking thank you
thank you for your answer that me help to much.
excuse me for my English
Old 06-02-2004, 02:30 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Steve
I can't say for sure, but they are probably low-point drain valves for your bathroom fixtures. open those to drain all the water out of the lines.
the 73's have them under the galley sink, as pictured above (one of those drains the fresh water tank), and also under the bathroom vanity. The winterizing instructions are simple: open those valves, raise the jack all the way up, wait until water stops flowing out of those rear drains...then lower the jack all the way, and wait for the water to drain out of the front one's. Probably the same deal for the 71's, too...although, different models locate the valves in different spots.
Frederic: as a fellow 23' safari owner, I can confirm what was said above...except I don't have "D". I was going to guess maybe that was an "accumulator", which is a device that evens out the pulsing output of the pump. Could be a filter, too. my original water pump has been replaced, so I don't have those parts. I don't remember seeing either a filter or accumulator mentioned in the owner's manual, so it could be something that someone else added.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Seweer valves broken JLD Waste Systems, Tanks & Totes 3 12-02-2003 07:04 PM
Argosy rear air bag leveling valves. Mark K Airstream Motorhome Forums 5 09-15-2003 04:34 AM
Leave Propane Bottle Valves Open? heyskipper LP Gas, Piping, Tanks & Regulators 3 02-23-2003 08:19 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
