Old 09-18-2013, 02:28 PM   #1
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Valve ID?
Obviously a drain valve, but from what? Inside the street-side forward storage compartment, next to the water heater, on the 25 FCC 25 FB. Don't know why the photo rotated to the left. Maybe it's the IPad.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 09-18-2013, 02:43 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Are you sure it's a drain? My first guess would be a shutoff for the outside faucet.
Old 09-18-2013, 03:07 PM   #3
Will_Brule's Avatar
Palestine , Texas
Definitely a drain. The line turns down through the floor just to the right of the valve, ending as an open pipe about 2" down.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
Old 09-18-2013, 03:26 PM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Image size you upload impacts orientation in a random manner. The larger the image, the more likely it will be on it's side or upside down.
I have found that a 3" x 5" image under 200k posts correctly and that is big enough for most folks to see what the object is.
