Underbelly Tank Cover Removal
Beneath the trailer there is a square galvanized pan covering the tanks. The drain to dump comes out of it and I can see through an imperfection there are water lines in it. It is held up by what appears to be lag bolts at its perimeter.
I would like to remove mine. It has water in it. I get random leaks when I use my tank rinser, fill my fresh water tank and when I fill my black tank to the max. I have now taken engough things apart on my trailer to realize the workmanship is horrendous, I have found more leaks and bad wiring then I thought possible.
I would like to drop this pan to access the leaks and go through everything. I know I will find many things to tighten and repair.
Thanks for any help.
