Old 04-11-2006, 06:53 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Two plumbing dillemas, pictures included
God you gotta love PO's. The things they will do to avoid fixing something right. The first picture shows where the pressure regulator from city water was removed and bypassed with garden hose and hose clamps. Of course this leaks and has rotted out the floor.
Now question to all you plumbers out there, how do I fix this the right way? Is there some sort of pressure fitting I could put on the end of those copper pipes that would get me a better seal on the garden hose?
The next picture show my other problem in the back end. Both of the valves to empty the water system leak and at least need to have new washers put in them.
Now I tried turning the top cap nuts on these things as hard as I could but I thought if I got out any heavier artillery on them I'd just crack them off. I don't know if these are the original valve or not but they look like it. Any suggestions on how to fix or replace?
HELP!!
wacnstac is offline   Reply With Quote
Old 04-11-2006, 07:18 PM   #2
Images: 43
Anybody ever use a product called "Just for Copper" for soderless joints between copper pipe? Does it work?
Old 04-11-2006, 07:40 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Qest has a fitting that will allow you to connect from copper to copper or copper to PEX. I would recommend the PEX as it's way easier than getting a tigt waterproof solder joint. Check your local Lowes for the Qest.
Old 04-11-2006, 08:43 PM   #4
bill benton's Avatar
Mansfield , Texas
Thats a mess. Rip it all out but the pex, and start over. You could use compression fittings for copper they have a rubber seal and tighten like brass fittings. They are called dresser or dresher fittings. I haven't used them for anything in a long time. They work fine but I would take it all out back to the pex.
bill benton is offline   Reply With Quote
Old 04-11-2006, 08:46 PM   #5
Texas Safari's Avatar
1964 22' Safari
Red Oak , Texas
My trailer has all sweated copper. Is Pex any better? Does it have any advantages over copper?
Texas Safari is offline   Reply With Quote
Old 04-11-2006, 08:57 PM   #6
Images: 43
Ok, what about fixing those valves. Any suggestions? If I crack the nut on the top of them I'm really screwed I think.
Old 04-11-2006, 09:05 PM   #7
Frank S
peoria , Illinois
Hi wacnstac--Your garden hoses leak because they have hardened and rotted. I have successfully used 5/8" soft clear plastic tubing installed with stainless steel clamps mounted the same as the hose in your picture, without leaks for 18 years. You get a much better seal with the clear plastic tubing, and it stays flexible. I have redone all the area you show, including the valves, which are on/off ball check type, in plastic. The wood damage you show looks to me to have long duration, and was probably the result of the leaky copper. The freeze cracks in copper usually seep and PO probably let them drip for a while before the hose repair. You also have some hard plastic repair work that looks like it replaced the originial copper pipe that supported the originial water pressure regulator, that probably also cracked. If it were me I would replumb the whole rear end with soft plastic. Won't burn down your A/S with your propane torch. Your photos are great. Really show your problem clearly.--Frank S
Frank S is offline   Reply With Quote
Old 04-11-2006, 09:08 PM   #8
Mansfield , Texas
I would prefer all copper if I were redoing my plumbing. Pex is ok I just like something a little more permanent. For the valves; instead of tightening the retainer nut loosen an if possible remove the top. Look to see if anything is left to repair inside. Plastic disk, o-ring etc. If the valve can easily be removed, take it with you to a plumbing supply and buy a new one. There cheep.
Old 04-11-2006, 09:25 PM   #9
Images: 43
I don't think those valve can be easily removed. I could unscrew the screw holding the handle in place but all that will do is take the handle off. Gotta get the large plastic cap nuts off of there to get at whatever is left of the washer.
Old 04-11-2006, 09:53 PM   #10
Frank S
peoria , Illinois
Hi wacnstac--Something to consider is your A/S water pressure is 40 to 50psi, while your house could be 90 to 120psi. You don't need the strength of copper in your trailer. Using hard plastic pipe, PVC pipe, with glued joints is also an option. It is a lot easier to use, and less expensive than Pex. Probably the best repair option is a combination of PVC, with soft plastic tubing in the areas that are difficult to get to. Happy plumbing.--Frank S
Old 04-12-2006, 12:08 AM   #11
1992 34' Limited
Falls Church , Virginia
PEX - How do I tell????
Hello all -
LOVE the photos. As the expression says, "I picture tells a thousand words..."....
Can tell the hard plastic from the copper, momma didn't raise no COMPLEAT idiot, but how do I know if I have PEX in there?
Is there an imprint down the side, clear plastic tubing is something I know from keg-er-ator plumbing.
Still wondering!?
Axel
SilverToy is offline   Reply With Quote
Old 04-12-2006, 02:43 AM   #12
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
WACNSTAC,
Do yourself a favor and get some quality brass ballcock valves. Quarter turn on and off, direction of the handle indicates if the valve is on. They don't cost very much and will last longer than the trailer. From there the type of plumbing you use is up to you and your skill level. I personally would chose copper, but this requires some knowledge of the tools - mainly the propane or NAP gas torch. A quick and good solution would be a barb fitting on the end of the valve and clear plastic tubing with SS hose clamps, probably would do you for a long time.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 04-12-2006, 05:37 AM   #13
Images: 43
Originally Posted by clancy_boy
WACNSTAC,
I'd like to replace with some nice brass ballcock valves, but the problem would then be splicing into the rest of the system. Do you think I can find a barbed fitting that will splice into the existing hard plastic? What are SS hose clamps as opposed to regular hose clamps?
If I go to home depot exactly what am I looking for if I want soft plastic tubing? My expected pressures on this system are not going to be large.
Old 04-12-2006, 05:55 AM   #14
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
SS stands for stainless steel, they cost pennies more but won't be rusted shut when it comes time for you to take them off later. As far as the barb fitting (I believe that is their correct name) yes you can get them at Home Depot in brass (recommended) or plastic. Either way the connection to the hose will be better than on smooth pipe. I have no doubt that others have had success with transitioning from smooth pipe to hose with a clamp BUT if for some reason there is a sudden increase of water pressure (say the regulator fails) than this method will hold more effectively.
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
Re-arranging pictures in Photo Gallery davidz71 Forum Admin, News and Member Account Info 9 09-09-2002 08:52 PM
