Old 09-09-2005, 08:20 PM   #1
Images: 13
Total copper replacement
Im going to replace all of my copper from the tank to the water heater and everything in between tomorrow. I have my 68 Safari gutted with my new and refinished cabinetry in my finish shop so I guess now is the time to do it. Any advise, do's or dont's or info that may be of help?
Thanks, Scott
68 Safari
niss1679 is offline   Reply With Quote
Old 09-09-2005, 08:24 PM   #2
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Pex.....great stuff, easy to use.....nuff said.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-09-2005, 08:36 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Thanks, Scott
68 Safari
I am using Pex and flair-it fittings in the rebuilding process of my 1963 Overlander, but only because it's the easy way out, and I am not an accomplished plumber. ( neither do i want to learn right now)
However, if I had the skills to do it right, I would use copper, most likley. I imagine perfect runs of elegant copper tubing inside the new cabinets, and quality and style come to mind. Instead, I will be looking at plastic tubing.....
Uwe
www.area63productions.com
Old 09-09-2005, 08:52 PM   #4
Images: 13
I've already purchased the copper. I figured I'm taking copper out so I'm putting copper back in. The condition of it looks good and usable, but since everything is out now, it would be silly to not replace it being 32 or 33 years old. Pex does seem to be the way of the futer though. I know some contractors who use it in new homes all the time.
Thanks, Scott
68 Safari
Old 09-09-2005, 08:58 PM   #5
San Angelo , Texas
Images: 37
I'm a real sucker for originality, but I'm an even bigger sucker for simplicity, and Pex is the epitome of simplicity.
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 09-09-2005, 08:58 PM   #6
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
I have repaired the copper in our trailer. PEX has some great benefits that should not be overlooked. I would seriously consider using PEX if I were replacing the volume of pipe you are.
I know its easy for us to do, but don't be fooled by the shinny metal.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 09-09-2005, 09:17 PM   #7
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Having replaced copper in both the '72 Overlander and '73 Sovereign, I would suggest replacing as little as necessary, only because it's a lot of work and does take time. (Once you've heated, fluxed, and sweat your fittings together, it isn't going to look near as good as the copper does when you buy it on the roll. And once all your furniture is back in place, you'll never see it anyway.)
If you don't have a swage (sp?), you might need one as I had some problems joining the old lines with the new. I'm not sure if the old had expanded (probably in places) or if the diameters were a little different 30 years ago. The swage allows you to ream out existing copper to insert new without using a coupling.
Buy lots of extra fittings as it's a real drag to have to stop work to go back to the hardware store. Wear gloves to save your fingertips from excess wear and burns. Keep a bucket of water nearby to cool fittings. Have fun!!
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 09-10-2005, 06:17 AM   #8
Images: 13
OK, I've had my coffee and now going out to get started. I appreciate all the advise and experience. I never gave PEX a thought and am going to Lowes first to look it over before actually starting. I also did'nt give only replacing what's nessisary in copper a thought either. I'll go to Lowes, re evaluate my 3 options and let you know tonite what I've done.
Thanks Again, Scott
68 Safari
Old 09-10-2005, 06:29 AM   #9
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Here is a pic of a swage (?) being used for a different application.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 09-10-2005, 07:03 AM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Being the son of a Plumber, I am a copper guy. Nothing wrong with Pex, just love the smell of soldering It can be a pain, sometimes, such as when you are working around the bathtub
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-10-2005, 12:22 PM   #11
All of the four trailers I have restored had come from northern states and had several splits in the copper. The inherent problem with copper is that when water freezes in copper it will expand WELL to either side of the rupture. Not only do you have to replace the area that has split but you have to go, sometimes, several inches to either side of the split to have tubing that you can get fittings to even fit.
I used copper 22 years ago in the 1963 Bambi and I swore that when something else will work I would use it. I used CPVC in the Argosy 24 and the Argosy 22. The Minuet has PEX and CPVC. It took me a day to do ALL of the plumbing in the Minuet using this combination.
I have learned from experience that if you fix one leak, you will eventually find others.
I am sure that my being from a state that freezes solid for three months out of the year has slanted my opinion. Here in Michigan things freeze and burst.
I found 8 ruptures in my Minuet. I also had six "repairs" that has been made using rubber hose and hose clamps.
PEX can prove to be expensive depending upon the types of fittings you use. I used a combination of crimp and compression fittings. I used QEST compression fittings where I joined the CPVC to the PEX and the CPVC to the copper for the city water hook-up.
Anon is offline   Reply With Quote
Old 09-11-2005, 06:02 AM   #12
Images: 13
Well, heres what I started to do yesterday. After carefully inspecting what I have in copper and hose patches, some of what 's there is in great shape. My Safari must have been in cold climate too, since I have a few places where the copper is split. I also found that my main line from the h2o tank to the water heater is 5/8", what's up with that? I've decided to only replace what is bad as well as all of the shut off valves. I didn't get as much done as I wanted to though. My wife got home from work and wanted to go out to eat. She said that I am obsessed with my silver lady! I think she's right. I only bought it on the 26th of August. Since then I've reworked all of the windows and installed new weather stripping, fabricated a new rock gaurd and installed it on the front window, got the antena working by fabricating new locking sleeves out of PVC fittings and thumb screws, gutted the cabinetry and flooring, cleaned the interior skin, built and refinished new and existing cabinetry, got the 12 volt sysem working and replaced all bulbs, painted the tongue and step, installed new locks on the exterior access doors, cleaned frames and replaced all screens with new, replaced a 16" x 5' section of floor by the door, installed a new dead bolt on the door (someone had one there before so there was a hole already there that needed plugged), and built new counter tops (waiting on the laminate to finish them). I havn't stopped working on her since I got her 2 weeks ago! OK, Ok, I am obsessed. I've had my coffee, so I'm out to finish (hopefully) the waterlines so I can start reinstalling the cabinets this week. Thanks for all the help and I'll keep you posted on my progress.
Thanks, Scott
68 Safari
Old 09-11-2005, 08:54 AM   #13
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Aluminitis
Thanks, Scott
68 Safari
You do have a bad case of it....
Uwe
Old 09-11-2005, 10:44 AM   #14
Scott, if you're not cured when you've finished those jobs, you may wish to remove the belly pan to inspect the corrosion in the frame. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Copper Canyon (Barranca del Cobre) Pahaska On The Road... 0 07-25-2002 07:14 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
