07-17-2018, 11:29 AM
1984 27' Airstream 270
Scotia
, New York
Too hot? How about misting the roof?
Just thought I would throw this out there after the recent heat wave.
My single AC unit is not powerful enough to battle direct sun in the 90's on a 27' motorhome. The indoor temp was 100 when I turned on the AC and I can only get down to about 90 deg. after 2 hours. (Yes I know 2 AC units are better than one, but I only have room for one.
I have a 16' misting setup I use for the kids (young & old) to cool of at events I go to. I run it off the rv water supply through a filter and it works nice with very low water usage.
I wonder what would happen if I suspend the misting tubing a few feet above the RV roof, from end to end?
Would it have enough evaporative power on the skin and around the AC condenser to reduce the inside temperature more than the 10 degrees I get now?
Insert opinion here:
Do not take life too seriously.
You will never get out of it alive.
07-17-2018, 12:06 PM
2007 22' International CCD
Corona
I can see the possibility that misting the roof, and from there, most of the AS. If the relative humidity in the area is low, it could provide some added cooling.
There is a downside or three:
1) Misting the roof would run the risk of mineral deposits on the roof and all the stuff on the roof as the water evaporates uncontrolled off the metal surfaces. If the water is alkaline, it can easily etch or corrode any unprotected aluminum.
2) Water on the roof is an invitation to find places for the water to leak into the structure wherever it can find a path. It's also a nice way to encourage the growth of algae and mildew if prolonged.
3) It's going to take a LOT of water to get significant cooling. At least around here, we are still in a drought, and the local authorities might take a very dim view of 'wasting' water.
I do see the utility of misting under the awning where the humans and pets hang out--that would be refreshing, and if properly positioned, would not get too much aluminum wet...
07-17-2018, 12:24 PM
Lin
, Ne
Umm, park under a tree.
07-17-2018, 12:31 PM
Princeton
, New Jersey
I have had it so hot that the AC would not remain on do to excessive head pressure. I had to play water on the condenser coil to lower the head pressure till it was low enough to allow the AC to remain on. The inside temp of the trailer was 107 when I started.
2004 Excursion 4x4
07-17-2018, 01:20 PM
Scotia
, New York
We are going to the NY State Fair in August, and no trees will be in the camp area, basically a giant parking lot with hookups.
I am not sure of the water quality there but it will be filtered for minerals, but not PH balanced.
The mist nozzles produce a very fine spray and with 10 nozzles it should use less than 5 gallons per hour, much less than any rain storm or any concern for the water department.
I have tied the misting line to the awning before, and as great as it feels, it does make everything damp after a while. It works best between 2 trees about 3 to 5 feet above your head to allow the mist to cool the air as it flows downward over you. The perfect setup evaporates all the water before it hits the ground. The 150 deg. skin should help with that, but as mentioned, stains may be a problem. The skin on my MH is so oxidized, it wont be noticed.
On the next 90+ heatwave with full sun I think I will try it.
In my mind (whats left of it) I figure to run poles on a rotatable bracket attached to each bumper. The mist line will be bungied between the poles, with someone in the front & back, rotate the poles vertical and lock them in place.
Pause for special news report on TV...
OK I'm back, and I checked my text to be sure I used the word "would" and "wouldn't" accurately.
I think I said what I meant the first time
07-17-2018, 01:29 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
We have a 27' trailer with a single AC.
The late start on cooling after a day of travel is hard to overcome.
We close the divider curtain and cool half the trailer, to get living area cool enough to have dinner. After the sun drops a bit we open the rest and run a fan.
By time to sleep it gets much better.
If parked for a few days, we sleep with it as cold as it will get so the AC has a head start the next day.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
07-17-2018, 02:20 PM
1977 23' Safari
Niagara on the Lake
, Ontario
I’m interested to se how this works or doesn’t.
I seem to remember someone asking about suspending a sun shade above their trailer to help with heat. Can’t find the thread now but that could work too.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
07-17-2018, 02:46 PM
Alamo Heights
Regards,
JD
You mean to tell me Airstream air conditioning has a setting OTHER than "as cold as it will get"? It's a binary thing for me, "off" or "arctic"
— David
07-17-2018, 02:54 PM
2018 28' International
Fayetteville
, Georgia
Glad I opted for 50 amp/dual air. No problem maintaining 72F in recent 95F temps...
brick
brick
2018 International Serenity
Cute wife...
07-17-2018, 03:30 PM
Scotia
, New York
I have 4 solar panels around the front vent, so there is no room for dual AC units.
Those 4 100 watt panels probably do help a little with keeping the heat down inside with less sun hitting the skin
07-17-2018, 04:11 PM
Corona
Getting the mister line high above the roof seems to be a good idea. It's worth a try, so please report back on how well the idea worked. Might want to use a piece of nylon rope to help support the mist line tubing and avoid stretching/breaking it. It's usually thin vinyl tubing that needs support.
I live out in a very dry desert, so dampness build-up is not usually an issue. In New York State, I can believe much higher humidity...I've been in Owego in the summer next to the river. Steamy at times!
Please keep us posted on this experiment...
07-17-2018, 04:30 PM
Scotia
, New York
The rope is a good idea to keep the mist hose from coming apart.
We are not suppose to hit the 90's for at least a week, but direct sun on the skin can still get the interior over 100.
I will do a test as soon as I can and report the results.
BTW, today's humidity is now down to 87%, it was close to 100% after the rains, that brought the temps down from the 90's to the 80's
Misting probably would not help for those conditions.
07-17-2018, 05:03 PM
Corona
Misting and evaporative (swamp) coolers usually work best in humidity under 30% relative humidity. Above that, evaporative cooling just gets clammy wet, and the dogs hate it, because they can't pant to properly cool themselves.
Around here, we easily get below that 30% RH in the summer (and darn near any other time).
95% humidity is not going to be easy to handle. The mister will make it hit 100% and not cool much, if at all.
07-17-2018, 05:40 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Have sprayed the trailer to help with cool down. Worked well. Is not allowed in many campgrounds. But it was very effective.
07-17-2018, 06:16 PM
1962 24' Tradewind
Buffalo
, Wyoming
This is an interesting thought. I have no answer, but it makes me wonder. Back in my climatology classes in college, we had discussions about the reflectance of solar radiation. Some surfaces adsorb short wave radiation and change it into heat. Some surfaces reflect the short wave radiation back as long wave radiation, which reduces heating. The example that was always given was that a dry concrete surface was always hotter than a wet one, because the wet surface surface changed the short wave to long wave radiation. So, the test question was: what is the best way to make the patio cooler on a hot day? The answer was; poor a bucket of water on the patio.
Soooo, would wetting the surface of an Airstream have the same effect? Might be an interesting experiment.
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Misting will help a lot, but water deposits will build up on the trailer. I know this by experience.....
If you wash with CLR a couple of times a week, the buildup can be mitigated.
07-17-2018, 07:19 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Misting will not be as bad for the trailer as the acid rain we get in the east. I would give it a try.
I've used a water hose to cool off the trailer, but not continuously. It helps.
Alan
07-17-2018, 07:30 PM
1972 31' Sovereign
Benton
, Arkansas
Two summers ago while parked in New Mexico I misted the roof of the trailer constantly for a few weeks in the heat of the day, it cooled the trailer considerably while lightening the load on my ancient air conditioner considerably.
In the time since I’ve erected a canopy to deflect the direct sun so I don’t mist the roof anymore.
When I was misting the roof, the lime build up was considerable, but the cooling of the trailer skin was substantial. I had to use acid to clean off the scale, but I would do it again if I didn’t have the cover.
This is what I do now.
07-17-2018, 07:35 PM
2016 30' Classic
Naperville
I also have found that this works well in hot west and southwest.
Ed
2016 Classic (with ProPride)
2016 Silverado 3500HD Diesel drw
1995 & 2004 Gary Fisher Hoo-Koo-e-Koo emergency vehicles
07-17-2018, 07:37 PM
2000 25' Safari
Davidson County
This is what I do now. Attachment 317312Attachment 317313
The OP is in NY, where their water comes from the Great Lakes and Finger Lakes. Minerals there are different. Still potash used in lead mitigation in the water systems will leave white residue from evaporation. If done short term buildup should not be bad. Maybe the acid rain will wash it off
ps
I'm curious about those Mason jars hanging on the awning poles. What is their purpose?
Alan
