Old 07-20-2015, 06:56 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by Cardinal283 View Post
Makes me wonder why you're sticking you hand in the toilet water to check the temp. ; )
I as wondering the same thing, but thought it might come under TMI.😜
MICHAEL
Old 07-20-2015, 07:11 AM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Maybe it's the sensation you get while sitting & flushing....
Old 07-20-2015, 07:38 AM   #17
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The bathroom lavatory cold faucet in my trailer runs hot for a minute, then cools down. I think it because the piping is next to the water heater or next the outside wall of the trailer on a really hot day. The piping I think is picking up ambient heat because it is next to hot water piping. I have not noticed the toilet water being hot, but it I guess it could be for the same reasons the lavatory cold water runs hot. I don't notice it so much when it is cold outside.
I have also noticed the cold water taps in the house run hot on a hot day, sometimes for a moment, sometimes indefinitely. It is so hot lately, the ground is hot- heating up the pipes in the ground.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-20-2015, 08:31 AM   #18
Cardinal283's Avatar
Dallas , Texas
This was my initial thought. Obviously if you let the water in the bathroom run for a little while you could test this theory. Or wait till winter to stick your hand in the toilet. ; )
Cardinal283 is offline   Reply With Quote
Old 07-20-2015, 08:43 AM   #19
1976 31' Sovereign
Oswego , Illinois
There has never been any mods. or work done except change furnace, water pump and convertor as I have owned this 1976 AS since pur. new. 3 yrs. ago in my 76 AS the toilet water runs hot and winterterize bypass kit valves are in proper position. I never change position of them as I don't winterize trailer. The spray hose for toilet also runs hot water, I haven't fig. out yet but still trying. If some else also has had this prob. and solved. post so I can see if I missed any thing. This not caused by ground or out side temps. causing water to be hot. Water will run cold for while then gets hot. All other faucets okay.
Old 07-20-2015, 09:53 AM   #20
Gainesville , Florida
As someone mentioned earlier, are the tank heaters on?
Old 07-20-2015, 06:53 PM   #21
Zil
egg harbor city , South Jersey
The hot water can migrate into the cold water feed line at the water heating tank. This kind of depends on the routing of the cold water line. Heated water will rise. The cold needs to come into the tank from a lower position up to the top fill line.
Zil is offline   Reply With Quote
Old 07-20-2015, 07:10 PM   #22
mandolindave's Avatar
Zil appears to have solved it.
But why does the hot water appear only at the lav sink and toilet.
Maybe I was right too. When they went to check the kitchen sink, all the warm water in the cold lines was depleted
mandolindave is offline   Reply With Quote
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 09:45 AM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Hot Water not hot enough??!! maryehill Water Heaters, Filters & Pumps 15 04-24-2012 12:58 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
