Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 09-16-2015, 12:27 PM   #1
2006 25' Safari SS SE
Reno , Nevada
Toilet Closure Sticks "Open" Occasionally
Hi folks,
Yesterday I posted for the first time and received two responses that solved my problem ... thank you.
Today, a new question; the toilet part that retracts to let the waste fall into the tank sticks open every now-and-again. This requires shutting off the water and going two out of three falls with the foot pedal to get the base to snap back into closed position. Any suggestions on how to prevent this from occurring?
Dave from Reno Nevada
ddrinks is offline   Reply With Quote
Old 09-16-2015, 01:02 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would buy some 'valve lube' ... without water turned on... pour into the toilet and operate it a couple dozen times.. to fully lube the sliding parts...
Otherwise you may need to 'remove' the toilet and replace the 'valve'...
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-16-2015, 01:23 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Cooking oil works fairly well too. And you can spray the bowl with Pam or some other cooking spray which also protects the bowl from brown streaks.
TMI, right?
Paula
Old 09-16-2015, 08:28 PM   #4
1998 30' Excella 1000
Livingston , Texas
If the lube doesn't work, try slightly loosening the mounting bolts. If they are too tight, sometimes they can warp the plastic body of the toilet enough to affect the sliding blade.
Siegmann is offline   Reply With Quote
Old 09-16-2015, 09:02 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Good suggestions above.
I thought that was a feature? When we've just been out for a weekend, the black tank doesn't even get half full - but to dump the tank, I want it 100% full so I know it's all getting flushed out. So I slowly step down on the pedal until it "locks" in the open position and water fills the black tank. When I'm ready to close it, I step down on the pedal again and (as we say in New England) "wicked fast" slip my foot off the pedal and the mechanism closes (shutting the water off).
Is it not supposed to do that?
Old 09-16-2015, 11:15 PM   #6
rd tighe's Avatar
2007 25' International CCD FB
South , South Dakota
Images: 13
I would recommend going to Ace Hardware and picking up some plumbing lubricant (grease) you can grease the rubber seal and the valve should :coolfunction properly
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Old 09-17-2015, 11:14 AM   #7
1977 31' Sovereign
Lynnwood , Washington
I use plumber's grease. It works very well and lasts a long time.
What you hafta do is apply liberal gobs of grease the to the underside of the seal. You do this with the valve all the way open and the water turned off. Using rubber gloves is no foregone conclusion. LOL
Tom
TomKirk is offline   Reply With Quote
Water heater goes out occasionally... steveirving Water Heaters, Filters & Pumps 12 10-24-2013 06:06 AM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
911 Help ~ when in the "sticks" CaddyGrn On The Road... 0 08-24-2008 10:04 PM
it sticks up Frank's Trailer Works Ribs, Skins & Rivets 4 04-28-2008 02:45 AM
