Old 04-14-2016, 05:44 PM   #1
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
Thetford valve T handle repair
So I was doing the dirty deed and when the Thetford valve rod reached the top (open) and the handle broke. The valves were replaced in Tucson about 5 years ago and have always been hard to pull up. Unfortunately it is not a threaded end - it is a ball end. The manufacturer pressed the plastic T onto the rod. The T is now in two parts.
Anyone had experience gluing one of these back on? Devised another way to pull up on the rod with anything other than a vice grip?
Eagle & Bear is offline   Reply With Quote
Old 04-14-2016, 06:01 PM   #2
1981 31' Excella II
New Market , Alabama
Get or make a T-handle. All you need is something with a hole in it the size of the actuator rod then drill a hole through both and put in a split pin or something similar to hold it on there.
Perry
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
Broken Thetford Valve Handle casa3805 Waste Systems, Tanks & Totes 4 04-23-2011 06:20 PM
Thetford Valve Repair kennytheecat Waste Systems, Tanks & Totes 2 03-28-2009 02:55 PM
Thetford Slide-Ez toilet valve repair bwjohnson Sinks, Showers & Toilets 6 10-28-2006 08:44 PM
