Old 01-20-2012, 07:59 PM   #1
1971 18' Caravel
powder springs , Georgia
the back side of my caravel is an open tapestry
Removed six feel of the underskin of my newly purchased 71 caravel in order to rid it of damage and neglect only to discover zero holding capacity. Found a twenty gallon plastic tank measuring 30 x 40 and has a 3 and 3/8ths to 5 inch taper; 5 inch being the limiting factor. My goal is to plum everything to the tank pat myself on the back and moving on to the next priority. Any pitfalls to my logic?
bobmstein is offline   Reply With Quote
Old 01-20-2012, 09:40 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
You do not want to plumb everything to one tank. Read the threads here on why not.
Old 01-20-2012, 09:41 PM   #3
1974 Argosy 20
Kooskia , Idaho
You are talking about gray water, right? No gray water tanks on those years. I have thought about doing the same thing on my '71 Caravel but I would use a larger and deeper tank with some more capacity. You can drop the belly pan a couple of inches in that area without harming the road clearance. My '74 20' Argosy has a dropped tank in the rear which was still covered with a belly pan which had also been dropped about 3 inches. I can't show any photos, as I am not at home, but someone with a dropped tank and belly pan on an Argosy might post a photo so you can see what they did at the factory on the 20's. I have towed mine maybe 40,000 miles and never had a problem with clearance.
Old 01-21-2012, 11:19 AM   #4
1971 18' Caravel
Is it possible to install a black water tank and run a 11/2" pipe around the tank to a valve that would open and restrict the black water tank? Is their a valve that can open and close in two directions or would I have to install two seporate valves?
caravel
Windows won't lock open perryg114 Windows & Screens 24 10-29-2011 02:43 PM
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 04:11 PM
Supposed to be drip edge on Driver's Side? Johns5711 Land Yacht/Legacy Motorhomes 6 08-03-2011 05:03 PM
A Frame end open Sphere Guy Repairing/Replacing Floor &/or Frame 4 02-27-2011 02:48 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
