Old 07-26-2016, 01:45 PM   #1
2006 16' Safari
San Francisco , California
Tank Level indicator lights and BLACK water ??
Newbie here (but an engineer). 2006 16' Bambi.
Our Fresh water tank has hit yellow, been refilled and hit yellow again. No gray tank in the Bambi. My black tank indicator is still green.
Should I be worried that my black tank indicator is out?
Where will the first evidence of black water overflow be?
Has anyone with a 16' calibrated when the indicator lights change from green to yellow to red for the fresh and black tanks?
I plan to run a calibration exercise as soon as can. Empty the black water, fill the fresh. Pump fresh into 1 gallon jug, pour into the black water tank via the drain, check the indicator lights. Continue to loop until black water overflows if practical, refilling fresh water or dumping the black water if needed.
Thanks!
New to land cruising! New to retirement! YUM!!!
SagaCapt is offline   Reply With Quote
Old 07-26-2016, 01:54 PM   #2
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Those indicators are notoriously not very accurate. As far as the black water you should be able to look down into the tank and see the level, when you flush.
Hiho Silver is offline   Reply With Quote
Old 07-26-2016, 02:03 PM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I purchase a inline water meter to attach to my water hose to measure how much water goes into a tank. When I recalibrate, I disconnect the other tanks sensors vs trying to perform the Micropulse procedure for individual tank calibration. I also take the trailer off shore power and let the battery voltage stabilize. When I fill the tank to calibrate the empty and full tank readings I wait for several minutes at each position to let the sensor react to the water level before proceeding to the next step. My Micropulse kinda works well enough not to consider switching to a SeeLevel system yet.
Good luck
Kelvin
Old 07-26-2016, 03:14 PM   #4
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
The sensors are often inaccurate or do not work. My solution : All tanks (5) have an overflow through the bottom ( closed off or on ) at 80 % level .
Greetings from Switzerland - Werner
Cruiser6483 is offline   Reply With Quote
Old 07-27-2016, 11:48 AM   #5
2014 30' Flying Cloud
Milton , Ontario
These devices never work accurately if at all. I worked in the Water /Wastewater business all my life and the only reliable device is a simple dip stick.
I performed a volume check on our 30' FC and pretty well got to the tank volume specified.
I used a two gallon water container filled from the city water system ( don't know why you are using yours from your fresh tank).
I got the plumbing drawings from Airstream and found out the sink in the bathroom drains into the Black tank. Well then you try to calculate how many times you wash your hands and shave and use other water devices like a water pik and soon your Black tank is full. I now know, from experience, that I can go about four days without dumping. As a previous responder said, just look down the toilet and note for future reference. By the way I checked the level device as I was test filling the tank and it was nowhere near what was actual.
Norrie
Norrie46 is offline   Reply With Quote
Old 07-27-2016, 12:39 PM   #6
dznf0g's Avatar
Oswego , Illinois
Look into a SeeLevel system. After years of fiddling with the MicroPulse, I have dead accurate and consistent readings with the SeeLevel. Read this thread:
http://www.airforums.com/forums/f317...ns-133508.html
-Rich-
Old 07-27-2016, 01:08 PM   #7
3wd67rg's Avatar
I quit , I quit
Just another item on Airstreams that never works, and hasnt for years and the Airstream company has never opted to fix it. WHY Airstream, WHY?
Dysfunctional Veteran- does not always play well with others. 20 a day is 20 TOO MANY.
(Approximately 20 Veterans commit suicide everyday. Revised from 19; revised from 20; revised from 23; revised from 22. Even the VA is a work in process)
3wd67rg is offline   Reply With Quote
Old 07-27-2016, 01:31 PM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Maybe it's a trend?
We looked at a Pendleton in February and I was surprised to see a SeeLevel system in it. Maybe there is hope yet....
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-27-2016, 01:32 PM   #9
dznf0g's Avatar
Oswego , Illinois
They finally switched to SeeLevel in 2014 or 15....can't recall now.
-Rich-
Old 07-27-2016, 05:49 PM   #10
2015 28' Flying Cloud
Newtown , Pennsylvania
Mine is at the dealer now. When the gray tank is empty, it will read anywhere from 13 to 69 percent. The other tank levels read fine.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 07-27-2016, 09:07 PM   #11
1988 32' Excella
Robbinsville , New Jersey
Since you have a 2006 and say you have no separate gray tank, that should mean your gray goes into the black tank (most on here call that a combined black and gray tank though it really is just a black tank as you said). If this is the case the first point of overflow will be the tub/shower drain.
Old 07-28-2016, 11:11 AM   #12
2006 16' Safari
Thanks for the suggestions!
So it seems the fresh water gauge is dismally wrong, went to at about half full. The black water indicator seems Yellow at about 3/4 full.
Thanks for the info on where to see the overflow.
I'm looking into Seelevel now.
Old 07-29-2016, 12:02 PM   #13
3wd67rg's Avatar
I quit , I quit
Keep in mind that those percentage readings may be different on every reading. Ours are in fractions, we can turn it off and then get a different reading when we turn it back on.
Old 07-29-2016, 12:45 PM   #14
Wise Elder
Jammer's Avatar
2010 30' Classic
The Micropulse indicators are notorious. There are several problems.
1) They are typically calibrated wrong. You can calibrate them, but it's a fiddly time consuming process to do right. In particular you want to be sure that you don't overfill any of the tanks. The Micropulse works based on pressure transducers, so when you calibrate, you have to be sure that the fluid is at the top of the tank, not above. Most of the time the tanks, especially wastewater, are only a few inches high, and so if you overfill them to the point where there's even just an inch or two of standing water in the plumbing above the tank, there will be a problem.
2) They use RJ11 phone connectors which aren't suitable for the application, prone to corrosion
3) Blackwater tank in particular the sensors clog and read emptier than reality
4) Sensors themselves do fail although this is rare compared to other problems
5) Battery gauge provides no useful information other than, when showing 100%, confirmation that the converter is working.
Good luck. Black tank, just hold the flush valve open and look down to see how full it is.
Gray Tank Level Indicator oreillychris Waste Systems, Tanks & Totes 1 11-28-2015 07:09 AM
LP Gas Cylinder Level Indicator nickmeloy LP Gas, Piping, Tanks & Regulators 15 04-13-2013 05:26 PM
Electronic Propane Level Indicator Bigventure LP Gas, Piping, Tanks & Regulators 4 11-28-2009 07:09 PM
Level Indicator Alex Jacks, Stabilizers, Lifting and Leveling 3 12-03-2003 08:27 AM
Tank level indicator panel mcostanzo 2003 Safari 7 11-07-2003 09:27 AM
