Old 03-17-2016, 08:01 PM   #1
2012 27' FB International
Unhappy Strange problem with graywater tank
I have something really weird going on with my graywater tank. It was refusing to drain into the septic system two days ago. I tried plunging the shower where the water was backed up, I poured biodigester down the shower drain, I tried opening and closing and opening the valve that starts the flow into the septic over again. I did everything short of roto-rooting it.
After awhile I decided to try emptying the black water tank which was about 2/3 full at the time. It whooshed out with no problem.After emptying the blackwater tank I tried the graywater tank again and it whooshed right out, solving the problem.
Now, two days later, the problem is back, with the graywater backing up in the shower with a distinctive septic smell.
Now, I thought the black and gray water tanks were completely separate, so I don't understand how emptying the blackwater tank allowed the graywater tank to empty. I'm baffled!
Can anyone explain what's going on and offer a simple solution? Right now the blackwater tank only has about 5 gallons in it, so I don't think it's a good time to empty it just yet.
flyingfishy is offline   Reply With Quote
Old 03-17-2016, 08:16 PM   #2
Ottawa , ON
My guess? The air vent is somehow blocked.
Old 03-17-2016, 09:59 PM   #3
2015 30' FB FC Bunk
Ayer , Massachusetts
I'm curious if this problem has suddenly occurred and you have a history of it otherwise working correctly or if this trailer is new to you and it has never worked correctly. If it is the later, a former owner may have tried a mod that conected the tanks for some reason.
Ted S. is offline   Reply With Quote
Old 03-17-2016, 10:17 PM   #4
Ted S.
I've had the trailer since August in continuous use and this is the first time this has happened .
Old 03-17-2016, 10:19 PM   #5
How would I go about unblock in the vent?
Old 03-17-2016, 11:05 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Okay let's think about this. The pipes join lower down to a single outlet. Is it at all possible that when you pulled the gray water valve open, the valve really didn't open? I assume when you opened the valve on the black water tank, you had the gray valve closed. Then when you opened the black valve, the pressure of the discharge also pushed against the gray water valve. Then you pulled the valve and this time it opened? Could there be either something where the pull rod on the gray water tank is not actually opening the valve. To prove that back, I'd attempt to use a drain clean out cable and if the gray water valve is open but not draining, thread the cable from the outside discharge back into the gray water tank and see how far you get. It just may be that the valve is closed even though you think you have it pulled open? Even if the vent is clogged, you would get water out since technically the tank could vent through the sink drains in the trailer.
My gut feeling is either something stuck in the lower pipe or that drain valve isn't really opening.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 03-17-2016, 11:12 PM   #7
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
That's my first take too. Something is messed up in the drain valves assembly. Too bad there isn't an easier access to examine and service them. Anyway, that's where I would start. Good luck and keep us informed.
The ability to follow instructions is highly underrated.
Always be wary of stupid people in large numbers.
hhendrix is offline   Reply With Quote
Old 03-18-2016, 06:31 AM   #8
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Just my thoughts as i am definitley no expert. Based on what I read it appears to me that you may have a blockage or a sticky valve. If it was me I would do the following: I would fill both tanks with water then drain the black water tank followed by the gray water tank. When both are empty then I would flush with hose. Another option is after you fill the tanks take the AS for a short ride to loosen any possible residue in the tanks and then flush.
I was also taught when i first purchase our AS to dumb either some water/ or ice in the black water tank to loosen any gunk that might remain.
Again just a thought
urnmor is offline   Reply With Quote
Old 03-18-2016, 10:49 AM   #9
dwhitake's Avatar
1972 23' Safari
1978 31' Sovereign
Akron , Indiana
sounds like the air vent on the black tank.
dwhitake is offline   Reply With Quote
Old 03-18-2016, 10:55 AM   #10
1977 31' Sovereign
Lynnwood , Washington
Sounds like you've got a clog somewhere.
Flush out both air vents with a garden hose. Then fill and flush both grey and black tanks. If necessary, back-flush both grey and black tanks.
This will get messy if the clog persists and you hafta back-flush with 3" sewer fittings removed. So make preparation accordingly.
As a matter of routine maintenance, I use a garden hose for this sort of thing. Chances are, your plumbing will have a built-in pressure regulator. So, connect the hose to an outside faucet that has good pressure.
BTW - Harbor Freight has some handy drain flushing kits for this sort of thing.
Tom
TomKirk is offline   Reply With Quote
Old 03-19-2016, 04:29 AM   #11
2014 27' FB International
Lewisville , Texas
If you left the grey tank valve open when you opened the black tank valve some of the black tank water could have back flushed into the grey tank through the open valve.
Sounds like a clog in the grey tank which is unlikely, unless one of the tank cut outs has been floating around in the tank since it was new and just now it made its way to the valve. But I wouldn't think that would clog it completely.
I think the above suggestion to open the grey valve and shove a garden hose up their is a good start.
Let us know what happens.
NO NOIZE is offline   Reply With Quote
Old 03-19-2016, 06:49 AM   #12
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Lafayette , Louisiana
I have a 2015 27fb as well. I believe if you have black water in the tank flowing out with the valve open and open the grey water valve at the same time with not much in the grey tank, it is possible for some of the black to make it's way to the grey system. The pipes are smaller and can become clogged from tissue etc. I would try above what "No Noize" recommends. There are 3 vacuum valves in your unit. One under the closet, for the shower, one under the galley sink, for the sink and one in the water closet to the right of the sink in the wall cutout. The one near the shower may have gotten some paper caught up in it. you can find this by opening the door under the right closet door. (this would be the 1st place I check and might even replace this valve, they are cheap and avail at Lowes/Home Depot. If you had grey water in it during the winter, it could have froze and damaged the valve. The next thing I would do is go on the roof and check the two sewer vents an make sure they are clear, no bug/animals made a home there. Don't ya just hate sewer issues! Let us know how it is going.
"Ferdara" Mark and Michael Broussard-Hubbard
Aluminum pulling Aluminum 2018 F-150 4X4 Platinum, 3.5L V-6, 10 speed trans, 6.5 bed, Max Tow 3.55 Elec Locking axle, Roadmaster Active Suspension ~ 2015 Airstream Custom Ordered 27fb International Serenity - Lafayette Louisiana
WBCCI 11100
LaBigDogs is offline   Reply With Quote
Old 03-19-2016, 04:18 PM   #13
1998 30' Excella 1000
Livingston , Texas
I've previously read that the gray tank drain pipes were smaller than the black, but just thought that must be older rigs. Does a new 27' really have a smaller drain pipe leading from the gray tank?
Siegmann is offline   Reply With Quote
Old 03-19-2016, 04:40 PM   #14
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
My 27 has a vent pipe running up both sides of the bathroom door in the triangulated wedges on the inside door frame. Why one is bigger, it hides the step set in for the folding bedroom privacy screen. Both should be 1 1/2 abs for venting sewer gas to the roof on both grey/black tanks
Your issue can't be about one plugged vent pipe for both tanks. It has to be on the discharge/blockage side.
The vacuum breakers, closet, sink, wash basin, work as a vent pipe for the P traps. In a stick house/older RV there would be a vent pipe to the roof for every P trap too.
If the shower won't drain while holding water as the grey tank over fills, I would look at the vacuum breaker in the closet, along with the main discharge for blockage.
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 03-19-2016, 08:05 PM   #15
OK, it's fess-up time! As it turns out, there is absolutely nothing wrong with either my gray water or black water system! Such a goofball I am! What happened is I switched which lever was gray water and which lever was black water, in my scattered mind...So when I tried to empty the gray water the first time, I was actually emptying the black water, which was empty...then when I emptied the real black water I was actually emptying the full gray water....confused yet? Once I realized I had mixed the levers up in my mind I went ahead and filled the black water tank and then emptied it, then the full gray water, in the proper order. Oh well, live and learn! Thanks for all your thoughtful responses and views!
Old 03-19-2016, 08:24 PM   #16
2015 30' FB FC Bunk
I can see how this can happen. Makes me wonder if I have been doing the same thing, they don't label the valves black and grey.
Old 03-19-2016, 08:29 PM   #17
2012 23' FB International
Woodstock , Ontario
OK
just deleted my post.. Glad you got it sorted out ...and don't feel bad ...we all goof up now and then. Good thing it isn't more serious!
JCW
JCWDCW is offline   Reply With Quote
Old 03-19-2016, 09:22 PM   #18
Granbury , Texas
They don't do a very good job of marking the valves but there is a Gray Handle on the gray tank drain and a Black Handle on the black tank drain. That's how I remember....
cabinetmaker is offline   Reply With Quote
Old 03-20-2016, 01:49 AM   #19
Lewisville , Texas
HA!
That brought a big grin to my face! I also do not like the labeling on the tanks. I have been tempted to make "P Touch" labels and maybe I will. Thanks for letting us know the outcome. Glad it was an easy fix!
Thanks again for posting the solution and enjoy your rig!!!
Old 03-20-2016, 02:42 AM   #20
Sag Harbor , New York
Correction noted -- I thought something was flying fishy!
Thanks for the update.
Welcome to the human race . . .
What happens when you top out the graywater tank? Belbein Airstream Lifestyle 6 05-26-2014 07:31 PM
Practicality of trailers without a graywater tank Jammer Waste Systems, Tanks & Totes 10 02-05-2010 09:01 PM
Home-made graywater tank bhpowell Waste Systems, Tanks & Totes 9 08-12-2009 04:34 AM
graywater transfer pump urbanfood Waste Systems, Tanks & Totes 11 11-29-2006 10:59 AM
Broken graywater tank Eric74 Waste Systems, Tanks & Totes 1 07-15-2004 11:14 AM
