Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 06-13-2009, 12:45 PM   #1
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
Sink Fixture Removal
I'm in the process of clearing out the bathroom fixtures in my '72 Sovereign so I can work on the floor. Everything seems pretty cut and dry except for one snag--removing the sink fixture.
The problem is I can't access the screw-on fitting for the copper pipes that attach to the faucet. I'm a rookie in this regard, dealing with copper pipes. Any insight in removing these would be greatly appreciated.
ID:	82224   Click image for larger version
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 06-13-2009, 01:03 PM   #2
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
Most moen faucets installed in AS had tailpieces soldered into faucet,then they were soldered onto the 1/4 trailer line.I can see the soldered coupling in your picture.Easiest way to remove is cut the 1/4" line with tubing cutters,when you reinstall use 3/8" compression unions.Squirt a little WD40 on the union threads and they will tighten up a lot easier.To remove the faucetfrom the top you need a 7/16 deep well or nut driver.
Dave
easyride is offline   Reply With Quote
How to wire a new fixture cosmo9404 Lights - Interior & Exterior 2 10-07-2007 05:11 PM
removal of 63 globetrotter sink & lav faucets? ChicknKathy Sinks, Showers & Toilets 2 03-05-2007 08:04 AM
bathroom sink removal tbrom Cabinets, Counter Tops & Furnishings 7 10-23-2006 10:18 AM
One sink, two sinks, red sink, blue sink? Janet General Interior Topics 7 07-26-2006 07:17 PM
Shower fixture milesmason Sinks, Showers & Toilets 6 08-22-2005 10:13 AM
