Old 08-15-2015, 04:33 PM   #1
Okiestreamer's Avatar
1999 25' Safari
Adair , Oklahoma
Shower vacuum breaker leaking
The vacuum breaker in our shower is leaking badly in our 1999 Safari. Has anyone experienced this and if so, how did you fix it? Also, has anyone taken one apart? Being on vacation for 3 more weeks in remote Colorado, I'd hate to take it apart and make it worse so any help would be appreciated. The part is an Alsons Vacuum Breaker part #4900. Does anyone know were I can order one in case I can't get help fixing this one? Although it doesn't show in the pic, the rubber gasket is in place where the hose connects to the vacuum breaker.
Dave
Okiestreamer is offline   Reply With Quote
Old 08-15-2015, 04:55 PM   #2
2002 19' Bambi
Lafayette , California
Replacing it is best. Here is a thread covering the same thing:
http://www.airforums.com/forums/f446...ml#post1264905
The Hansgrohe product mentioned there is not expensive.
Tim
Tim A. is offline   Reply With Quote
Old 08-15-2015, 07:38 PM   #3
1999 25' Safari
Adair , Oklahoma
Thanks Tim! I'll check Amazon.
Dave
Old 08-22-2015, 07:55 AM   #4
1999 25' Safari
Adair , Oklahoma
Tim, got the new part an water comes out of the holes you see in the attached pic around the core. There is as much or more coming out of these holes than out of the shower wand. It appers that is the way it is suppose to work. The check valve works not letting any back flow into the main line. Do you know if this is the way it should work? Anyone else please feel free to chime in.
Dave
Old 08-22-2015, 09:22 AM   #5
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Same problem for us. Too much water coming out . I took the vacuum breaker off, connected the hose straight to the fixture.
The purpose of the vacuum breaker is to keep water in the shower head from backing down the hose, contaminating the fresh water. Just keep the shower head out of the toilet.
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 08-22-2015, 11:25 AM   #6
2002 19' Bambi
No, that is not the way it should work and is definitely not how mine works. I suggest returning it to Amazon as defective. A couple of reviews mention that it does what you mention under very low flow. You can find other brands on Amazon: http://www.amazon.com/gp/search/ref=...qid=1440263941
Sandlapper is right about the purpose of the thing. Standing water in the shower is also a potential contaminant.
Tim
Old 08-22-2015, 01:45 PM   #7
1999 25' Safari
Adair , Oklahoma
Ok and thanks. I'll send this one back and do the direct connection. We'll be boondockin for a few days so I couldn't imagine that leaking was the way is should work -wasting a lot of water. Thanks again and we'll order a another brand from Amazon.
Dave
Leak at vacuum breaker PAL07 Sinks, Showers & Toilets 4 04-28-2014 11:04 PM
Shower Vacuum Breaker in 2000 -34' jlovelady Sinks, Showers & Toilets 2 02-23-2013 06:04 PM
where can I find a vacuum breaker nipsey Plumbing - Systems & Fixtures 4 10-07-2012 05:57 PM
Vacuum Breaker on Toilet Hand Sprayer cal.caravel Fresh Water Systems 1 05-08-2012 09:29 AM
Toilet vacuum breaker Zeppelinium Sinks, Showers & Toilets 5 09-07-2007 04:05 PM
