Old 01-16-2015, 03:50 PM   #15
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The temp out of the water heater is not adjustable like it is on a home unit.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-16-2015, 04:13 PM   #16
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
FWIW
Part of the problem may be the way you initially arrive at your own perfect temperature. Virtually all RV systems suffer from some version of this behavior. The solution from the Beaver site, many years ago, was as follows:
1) Turn on the water full hot
2) add cold - rotate the single lever control in newer AS - until your temperature preference is reached.
Use the Navy Shower Button
BTW some complain that the shower drips when the button is "on." This is by design to remind you the water isn't off and to help you remember to avoid Paula's problem (we all been there, Paula).
The Ice Man is offline   Reply With Quote
Shower water temperature fluctuations Okiestreamer Sinks, Showers & Toilets 1 09-19-2014 09:32 PM
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 09:35 AM
Temperature Gauge cookieduster1 Mechanics Corner - Engines, Transmission & More... 5 04-26-2003 06:50 PM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
