Old 03-04-2017, 03:38 PM   #1
Ridgway , Colorado
Shower Sump Drain
So I am rebuilding a 62 Silverstreak And have discovered that I cannot get flow from my shower to my Grey tank.. I have found a few different shower sump drains that look like they would work, (Rule shower sump drain & Whale Gulley IC shower drain) has any body out there installed either of these products or anything similar. If so give me the good the bad and the ugly please. Access will be difficult so reliability is key.
Pickle62 is offline   Reply With Quote
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 08:42 PM
Shower sump pump? malconium Sinks, Showers & Toilets 18 08-21-2011 07:08 AM
Water Filter Sump Replacement elzavb Water Heaters, Filters & Pumps 1 01-11-2011 05:12 PM
water in sump Normin storm Mechanics Corner - Engines, Transmission & More... 2 11-12-2007 07:56 AM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
