Old 03-09-2012, 10:39 PM   #1
2008 27' Classic FB
Vista , California
Unhappy Shower leaks 2008 classic
The shower in our 2008 classic FB, leakes under the wall below the shower door. I tried to calk all around the door and under the threshold. Still leaked.
Next I removed the wall between the closet and the shower, no small task.
I found some screws that came through the fiberglass liner of the shower, calked those, reinstalled the wall etc., still leaked.
Can anybody out there help. I am calked to death.
WILLIAM P is offline   Reply With Quote
Old 03-09-2012, 11:02 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
William
Welcome to the forum. Sorry about your leak. Most of us have had water leaks, so we know how frustrated you are. You may want to load some photos, so we can help you better.
Dan
Old 04-16-2012, 06:20 PM   #3
2007 27' Classic FB
Ridgefield , Washington
William-Dont know if your still having the problem. I was getting water leakage around the corner of the shower door. The problem as far as I can tell is the plastic strip that is on the bottom of the shower door had a quarter inch space that was allowing water out. I tried to get Airstream to fix it but had no luck. Finally I bought a clear shower curtain and installed it inside the shower. Doesn't look too bad and leak problem is gone.
John & Lisa
Woosch is offline   Reply With Quote
Old 05-07-2012, 07:10 AM   #4
Guest
shower leak
Hi,
We have a 2000 excella 30. Same problem, water comes into tray on the shower door and leaks. Tried all sorts of caulking (everywhere) with no success. Installed shower curtain and fixed some of the problem. Still have occasional leak.
SK
searcher is offline   Reply With Quote
Old 05-07-2012, 07:17 AM   #5
dznf0g's Avatar
Oswego , Illinois
I had the same problem. Water was getting by the ENDS of the clear lip seal on the bottom of the shower door frame. I used a clear silicone sealer to build up a "dam" connecting the ENDS of the seal (bottom door sweep) to the vertical door frame members. Cured the issue completely.
-Rich-
Old 05-07-2012, 07:18 AM   #6
aftermath's Avatar
Spokane , Washington
I have a 2006 and mine was doing the same. At first I thought it was the door gasket at the bottom but when I looked closely, it wasn't leaking out of the front and there was no water from the door to the floor anywhere. It was coming out from the wall at the bottom.
I took the door off and removed as much trim as I could. I caulked this area and replaced the trim. I also noticed that my shower stall has a seam that runs around the whole thing as if the enclosure came in two pieces and this seam was caulked at the factory. Part of the caulking was missing from use or neglect by the installers. I caulked this and bingo, no more leaks. I don't know if it was this seam or if it was all the caulking around the door, but I got it stopped.
Good luck.
aftermath is offline   Reply With Quote
Old 05-07-2012, 08:15 AM   #7
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Ours used to do the same and on a trip to Jackson Center, we had them look at it. Turns out the shower door had been installed backward or upside-down (I can't remember which). They put a new door in and it hasn't leaked since (although I probably just jinxed it by saying that).
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 05-07-2012, 09:32 AM   #8
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
I was getting a lot of water out from behind the shower face frame at the floor.
Turned out, the cheap caulk used at the shower enclosure seam (where the two fiberglass sections come together) had failed. It looked OK, but after completely removing all the old stuff, cleaning, and recaulking, the leak disappeared.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 05-07-2012, 09:39 AM   #9
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
William, are you still there? If I understand your post of 2 months ago, water is coming out from under the wall under the shower door.
That could mean a leak from a lot of places: shower pan or wall, drain, hot or cold pipes to the shower, shower valve, somewhere nearby. If you haven't solved this yet, look for water tracks in the dust or water stains to investigate where the source is.
The screws coming through the shower liner sounds like shoddy workmanship. Replace with shorter screws and seal the holes on both sides. Sealing holes, cracks and such from leaks should occur mostly on the side where the water is coming from, but as a safety measure on both sides. There are epoxies made to seal cracks in the shower walls and floor. Check out this thread: http://www.airforums.com/forums/f446...elp-56051.html
Sorry your initial question never got a lot of answers—usually questions like this get a lot of responses, but yours fell through the cracks.
Gene
Old 05-07-2012, 02:37 PM   #10
Dearborn , Michigan
Images: 21
This is the seam, after I'd cleaned out all the old caulk
Old 05-07-2012, 04:38 PM   #11
O'Fallon , Missouri
Same problem...I was convinced leak was coming from under the shower. Tried the shower curtain solution and no more leaks.
But I dislike the curtain so I calked around the door and rail, kept as much as possible the spray away from the door and almost no leak. I did notice one thing though...when I opened the door a stream of water started down the outside of the shower to the floor. It was either released from the door rail or just running down the door.
'08 25' Safari SE
'13 Ford EcoBoost
aswbe is offline   Reply With Quote
Old 05-07-2012, 04:58 PM   #12
dznf0g's Avatar
Oswego , Illinois
Yeah, The water lays in the lower frame, just like at home, and drips off onto the floor when opened. But we keep a big thick comfy bath mat there that catches all that. No biggie.
-Rich-
Converting a Classic to CNG t7389sg Classic Motorhomes 9 06-23-2012 11:53 PM
Correcting Skin and Structural Damage Related to Leaks Steve Bryant Ribs, Skins & Rivets 16 05-22-2012 05:24 PM
2009 Airstream Classic 30' w/ Slide Out - Price Reduced!!! eBay Watch Airstreams on eBay 0 03-09-2012 08:30 AM
Trailer Leaks,...2009 to current.. THEPILL Off Topic Forum 23 03-06-2012 09:35 AM
2008 Interstate 3500 Generator Exhaust Routing Question solar-guy Sprinter and B-van Forum 3 03-06-2012 06:19 AM
