Old 07-02-2007, 11:00 AM   #15
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Her ya go Chuck-
PEX Tubing - Wirsbo PEX Tubing - ThermaPEX PEX Tubing - PEX Tube - PEX Pipe
Pricing and everything else! May just go with the brass fittings and crimp rings that they do in JC.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 07-02-2007, 01:47 PM   #16
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Originally Posted by rickandsandi
Was wondering where to find sharkbites withpout having to order on-line.
I bought my Shark Bites at my local Ace Hardware. They carry Pex also. Their web site is, acehardware.com.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 07-02-2007, 02:46 PM   #17
2005 22' Safari
1960 24' Tradewind
Neil and Lynn
Neil-
Do you have a part number? I just went to their site and got "0" in their search for PEX or Sharkbite.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 07-02-2007, 04:54 PM   #18
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Here are Sharkbite part numbers, I don't have the Ace numbers.
Straight 1/2" coupling is part # U008
1/2" Tee is #U362
Dave
Fyrzowt is offline   Reply With Quote
Old 07-04-2007, 04:59 PM   #19
ibgl6's Avatar
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
In the Home Depot ad today for the zip code 32404 (just in case it differs) they had several prices and displays for the shark bite fittings...
Your Friend Sam In (Southport) Panama City Florida
Air#15607 TAC FL-2
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 07-11-2007, 02:18 PM   #20
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by Chuck
what website were you on?... I'd like to see a price list, to do a side-by-side comparison w/ the sea-techs....
Chuck, Cash Acme has a Price list on the site you originally linked.
http://www.cashacme.com/2006_Pricelist.pdf
It would be nice if these could be used for the propane supply lines also. I did not see any indication that they could be.
Steve
byamcaravanner is offline   Reply With Quote
Old 07-11-2007, 04:04 PM   #21
FreshAir's Avatar
1966 24' Tradewind
Neil-
I just checked with my local Ace and they were surprised when they could not locate Shark Bite on acehardware.com. Their only possible explanation is that Ace just began carrying it. I am not necessarilly promoting Ace it is in my case very convenient as the store is 'just down the lane' from me. I knew I would need to make several trips with exchanges a new and different connections.
I was going to attach a picture of my water heater connections but the 'Manage Attachments' is not working. I will post the picture later.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 07-11-2007, 10:21 PM   #22
FreshAir's Avatar
1966 24' Tradewind
Neil.
The picture shows the view of the new Atwood WH as it looks from the top. I 'married' the Pex to the copper supply with Shark Bite connections. Then threaded Shark Bite elbows are wrenched to those. This was done before sliding the new WH in place. I installed a winterizing by-pass to the WH also before sliding the it in place with 2 more SB elbows on the by-pass. Now I slide the WH in place, anchor it, and connect the Pex between the SB elbows. Work space is very limited. No room for a wrench or crimping tool. I had to hold my arms above me to work my upper body thru the bathroom closet at a twist then right myself with the closet door frame squeezing my ribs. And I did this with arthritis and 2 titanium hips. Before inserting myself I placed the 2 pre-cut Pex tubes and a small pruning scissors (for minor trimming) on top of the WH as I plan to make squishing into that closet as few times as possible. Also included with the tools on the WH is the Shark Bite removal tool should I need to make adjustments. Shark Bite is too pricey for me to completely renovate my plumbing. However, with tight installations as this it is Priceless!
Neil.
Name:	Airstream - New water heater install 6-07 034.jpg
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Pex questions Bradjun1 Fresh Water Systems 20 05-15-2006 10:53 AM
Pex-Crimped vs Qwest fittings StingrayL82 Plumbing - Systems & Fixtures 15 11-02-2005 12:04 AM
