Old 09-21-2007, 12:43 PM   #15
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by clancy_boy
Hey MM - I'll need to use one at the NGa rally in a few weeks. Mind if I use yours? That way mine can stay fresh and clean.....
I'll have it with me I'm sure. You're welcome to borrow it so you don't have to bring yours all the way from MS if you'd like. Just no black tank stuff!
Family of Disney Fanatics
WBCCI# 4821
Old 09-21-2007, 12:46 PM   #16
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
I would consider a small tote and empty more frequently. It will take up less space in your tow vehicle and won't be so heavy or awkward to manipulate! Besides, think of it as a cardio workout! Besides, it will save $$ and less room to store at home. Then we are into "small"....
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 09-21-2007, 12:47 PM   #17
2006 30' Safari
Orlando , Florida
Originally Posted by jcanavera
Hmmm....Patty has an electric cart because of her bad knee. I'd be curious if it would make a good TV for the tote??
Well, I'm going to hit the road. I'll let you know what I see.
Jack
What's the GCVW max? Will the full tote exceed 80% of the recommended tow capacity? How about the wheel base, do you think it is long enough? What kind of brake controller does she plan on using? Does she use the standard 7-pin connector for the umbillical?
WBCCI# 4821
Old 09-21-2007, 12:51 PM   #18
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here's one for $119 - we just bought the 25 gallon version and it seems fine. There is also a little bobber you can buy that goes in the hose fill line - I think it's set to pop up when the tank is 3/4 full.
RV Waste Holding Tanks from Tote-N-Stor
Old 09-21-2007, 12:52 PM   #19
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
If there is a roll-over PLEASE DON"T post pictures!
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 09-21-2007, 01:08 PM   #20
Cracker's Avatar
Pittsfield , Maine
Jack:
I'd go for the 35 gal 4-wheel tote. The only problem is finding a way to transport it. As for towing it with the electric cart - sounds like a neat idea but it's bound to get a few fun comments on the way to the dump! Provided the camp road isn't full of ruts you probably won't have any problem with the wheels. I spent two or three weeks at Ft. DeSota (Pinellas County, Fl.) and never had a problem. The biggest problem with any of the totes, relatively to an Airstream, is the low height of the discharge on the AS. If you catch it before the tank is full, it's easy enough to lift up the hose and drain its contents into the tank before disconnecting it.
Cracker
Cracker is offline   Reply With Quote
Old 09-21-2007, 01:36 PM   #21
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Thanks for the laugh - too funny.
Old 09-21-2007, 03:05 PM   #22
2006 30' Safari
Orlando , Florida
I know that's right!
WBCCI# 4821
Old 09-21-2007, 04:32 PM   #23
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
That's just too funny .....but it just may be possible to pull it. I'll have to check the GCVW figures for her cart. It runs off of twin 12 volt sealed batteries. I think its a 24 volt system.
I just came back from two RV dealers and the one carrying the Thetford does not carry them in stock. Special order only.
I looked at the Barker Tote Alongs which ran $244 for the 25 gallon four wheel model. While the handle looks fairly substantial it's connected to a bolted plate on the bottom front of the tank. You almost wonder when loaded if those bolts might tear loose or possibly leak after a few full pulls.
It has a nice Valtera slide valve on the side along with some big rear wheels. Anything bigger than 25 gallons takes too much space in the rear of my van (along with Patty's electric cart, grill, tools, and turf that I bring along).
Considering I'd have to spend even more on tax, the Thetford unit which is 27 gallons looks to be a bargain at $200 which includes shipping and no sales tax and comes with all of the hoses, handle, and liquid level gauge.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-21-2007, 05:11 PM   #24
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Jack
Yes, you just need to rig a hook or hitch for the handle of the tote. This is the voice of recent experience.
Also, my experience with the Thetford tote is it has Valterra fittings. I bought an 18 gallon tote, and found out when I got it home I needed to go back and get the Thetford fitting for it.
Old 09-21-2007, 05:13 PM   #25
Well Preserved
1993 21' Sovereign
Jack
Jack, if Patty's cart is an Amigo, it is probably 24 volt, as that is what mine is.
Old 09-21-2007, 05:43 PM   #26
jcanavera's Avatar
Fenton , Missouri
Images: 143
No her's is a Pridemobility Victory. Maximum load 350 lbs. Hmm...maybe we need an axle change or make sure the path to the dump station is on a slight down hill tilt!
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-21-2007, 11:05 PM   #27
_
hi jack...
i've got the barker 4 wheeler in 34 gallon size.
the metal plate/bolts has held up well and doesn't leak.
the valterra side valve makes dumping really easy.
the 34 gallon version weight nearly 300 lbs full...
it is a major PIA to move just 40 feet from trailer to tow vehicle...
you would NOT like doing this.
that same 4 wheel/side valve model is available in 20 or 25...
which still weigh nearly 200 lbs full....
i'd suggest getting the smaller one...
with 4 wheels and side empty valve.
cheers
2air'
Old 09-21-2007, 11:17 PM   #28
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by 2airishuman
hi jack...
cheers
2air'
Wow. That is major. Out of curiosty, what is the physical size diference between the different sizes. Where do you stow them when you travel?
TinShack is offline   Reply With Quote
Totes versus Gray Tank Tom Bray Waste Systems, Tanks & Totes 17 09-17-2007 07:03 PM
Sewer hookup-what to get LI Pets Waste Systems, Tanks & Totes 64 12-31-2006 11:32 PM
HELP sewer connector - 1962 Globetrotter?? stagecoachbill 1960 - 1964 Globetrotter 1 08-07-2006 10:47 PM
Sewer Solution Craftsman Waste Systems, Tanks & Totes 4 09-12-2004 10:04 PM
Sewer Solution frozen chosen Waste Systems, Tanks & Totes 20 07-26-2004 08:05 PM
