04-12-2015, 06:21 PM
1994 34' Excella
Landisville I
, Pennsylvania
Sewer Hose Hook Up Problems
We purchased a 1994 35' Excella last year. Just got it to the campground to set her up after changing to a hardwood floor and replacing the upholstery, and a complete detail. Trying to hook up the new sewer drain hose, and the standard connector from the tank was slightly larger than a normal hose connection. Couldn't hook it up. We have have never had an issue with the diameter of the hose connector before on previous trailers/ motorhomes. I was assuming this was a standard size. Anyone ever run into this situation? Didn't know if it was a different connector because the trailer is 21 years old.
Any ideas?
04-12-2015, 06:33 PM
1994 34' Excella
Warren
, Manitoba
The stock fittings are Thetford, which is different than what most other trailers have. You will have to get the Thetford hose ends at an RV store or order them. Good luck, Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
04-12-2015, 06:50 PM
2024 23' Flying Cloud
San Antonio
There are "step down" adapters that snap on to take it from a Thetford to a Valterra.
04-12-2015, 07:03 PM
1988 29' Excella
Plant City
I got mine on Amazon Valterra T05-2285VP Thetford to Valterra Universal Adapter
04-13-2015, 06:51 AM
1994 34' Excella
Landisville I
, Pennsylvania
Sewer Hose
Thanks for the replies!
I'm new to using a forum, but not too old to learn.
There is a camping world store in Harrisburg, Pa that I will hit tomorrow morning.
Your help is much appreciated. I'm finding that campers are the same as the boating community. Doesn't matter what your station in life is, everyone is helpful!
Thanks again!
04-13-2015, 07:28 AM
1966 22' Safari
Hilltop Lakes
Get an extra Thetford to Valterra adapter while you're there. They break sometimes, and a spare might be good to have.
04-13-2015, 03:45 PM
2004 34' Classic S/O
Pahrump
, Nevada
I took a saw to the sewer line just behind the Thetford end connector. I little glue and a new "regular" bayonet fitting and the Thetford connector problems are gone for ever. Any decent RV parts house or Home Depot/Lowes store will have all you need.
04-13-2015, 11:34 PM
1999 34' Excella
Hillsboro
buy a couple of the Valterra/Thetford adapters. The little gasket tends to come unglued and you lose it.. then you have leaks.. then you LOSE IT! DAMHIK..
Peace and Blessings..
Channing
WBCCI# 30676
04-15-2015, 06:30 AM
1994 34' Excella
Landisville I
, Pennsylvania
Got the right stuff!
Thanks for all of the help everyone!
04-15-2015, 06:32 AM
1999 34' Excella
Hillsboro
Woo hoo!!! Mastering the POO!!!!
Channing
WBCCI# 30676
04-15-2015, 07:00 AM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
You can also purchase a small package of Xtra gaskets for the adaptor fitting. I went that route for awhile after I lost a gasket and had the leaks. Last summer I found a proper Valterra fitting and cut the old one off and installed it. Now everything fits.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
