Old 04-12-2015, 06:21 PM   #1
1994 34' Excella
Landisville I , Pennsylvania
Sewer Hose Hook Up Problems
We purchased a 1994 35' Excella last year. Just got it to the campground to set her up after changing to a hardwood floor and replacing the upholstery, and a complete detail. Trying to hook up the new sewer drain hose, and the standard connector from the tank was slightly larger than a normal hose connection. Couldn't hook it up. We have have never had an issue with the diameter of the hose connector before on previous trailers/ motorhomes. I was assuming this was a standard size. Anyone ever run into this situation? Didn't know if it was a different connector because the trailer is 21 years old.
Any ideas?
vilnis is offline   Reply With Quote
Old 04-12-2015, 06:33 PM   #2
1994 34' Excella
Warren , Manitoba
The stock fittings are Thetford, which is different than what most other trailers have. You will have to get the Thetford hose ends at an RV store or order them. Good luck, Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 04-12-2015, 06:50 PM   #3
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
There are "step down" adapters that snap on to take it from a Thetford to a Valterra.
Cannonball is offline   Reply With Quote
Old 04-12-2015, 07:03 PM   #4
1988 29' Excella
Plant City , Florida
I got mine on Amazon Valterra T05-2285VP Thetford to Valterra Universal Adapter
wjcwill is offline   Reply With Quote
Old 04-13-2015, 06:51 AM   #5
1994 34' Excella
Sewer Hose
Thanks for the replies!
I'm new to using a forum, but not too old to learn.
There is a camping world store in Harrisburg, Pa that I will hit tomorrow morning.
Your help is much appreciated. I'm finding that campers are the same as the boating community. Doesn't matter what your station in life is, everyone is helpful!
Thanks again!
Old 04-13-2015, 07:28 AM   #6
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Get an extra Thetford to Valterra adapter while you're there. They break sometimes, and a spare might be good to have.
Old 04-13-2015, 03:45 PM   #7
2004 34' Classic S/O
Pahrump , Nevada
I took a saw to the sewer line just behind the Thetford end connector. I little glue and a new "regular" bayonet fitting and the Thetford connector problems are gone for ever. Any decent RV parts house or Home Depot/Lowes store will have all you need.
DriveAbout is offline   Reply With Quote
Old 04-13-2015, 11:34 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
buy a couple of the Valterra/Thetford adapters. The little gasket tends to come unglued and you lose it.. then you have leaks.. then you LOSE IT! DAMHIK..
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-15-2015, 06:30 AM   #9
1994 34' Excella
Got the right stuff!
Thanks for all of the help everyone!
Old 04-15-2015, 06:32 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Woo hoo!!! Mastering the POO!!!!
Channing
WBCCI# 30676
Old 04-15-2015, 07:00 AM   #11
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
You can also purchase a small package of Xtra gaskets for the adaptor fitting. I went that route for awhile after I lost a gasket and had the leaks. Last summer I found a proper Valterra fitting and cut the old one off and installed it. Now everything fits.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
My Hook Things Won't Hook Sbb Rock Guards, Segment & Window Protectors 2 04-12-2015 06:16 PM
Sewer drain doesn't hook up Loeber Waste Systems, Tanks & Totes 12 10-10-2012 01:26 PM
Sewer hook-up rasberry Waste Systems, Tanks & Totes 5 06-16-2012 01:38 PM
Hook up OR Not Hook up while camping purman Boondocking 29 08-18-2009 06:42 PM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
