Old 03-31-2014, 06:30 AM   #1
1955 22' Safari
Laredo , Texas
Sewer hose connection
1964 Bambi 2.
Want to connect modern style sewer hose to fitting under trailer. New hose end connection is not compatible. Is there an adapter?
55AS is offline   Reply With Quote
Old 03-31-2014, 06:41 AM   #2
SStar's Avatar
2004 28' Classic
Midland , Texas
Adaptor
You will probably need an adaptor from Thetford to Valterra. This will allow you to connect the standard fittings, valves, hoses, whatever. Should be available on Ebay, local RV supply, Amazon.
SStar is offline   Reply With Quote
Old 03-31-2014, 06:42 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
That's right around the time that they switched to Thetford connections. What you're calling "modern style" is Valterra. You can get Thetford to Valterra adapters online or in many RV supply stores.
A photo would help since there were some older setups for which matching connectors are no longer available.
Old 03-31-2014, 06:54 AM   #4
1987 25' Sovereign
Oregon , Ohio
When I had the sewer discharge valves rebuilt I had a Valterra fitting put on instead of the Thetford. Now I can get hoses and fittings just about anywhere. Yes we have a vintage trailer, but I do not want to be stuck out somewhere with full tanks and broken fittings and nowhere close to get new ones.
msmcv51 is offline   Reply With Quote
Old 03-31-2014, 06:55 AM   #5
SStar's Avatar
2004 28' Classic
Midland , Texas
Take a look at the thread Macerator on 3/10/2014, it has some interesting discussion on hose adapters.
Old 04-25-2014, 11:07 AM   #6
1955 22' Safari
Laredo , Texas
My trailer apparently has an old style fitting which is not compatible with anything but it did come with an aluminum elbow that attaches to the waste fitting and I was able to fit a modern Valterra hose over the elbow after a bit of effort. Problem solved with no major outlay required :-)
What size Sewer hose connection? 72Blazerod Waste Systems, Tanks & Totes 6 09-20-2015 10:12 AM
1987 Sovereign 31 ft - Sewer Hose Connection? mredwine Waste Systems, Tanks & Totes 1 10-21-2013 05:14 AM
68 Safari sewer hose connection niss1679 Waste Systems, Tanks & Totes 5 04-29-2006 11:26 PM
A tale of woe - how I saved a buck on tires and destroyed my sewer connection dmreilly10000 Tires 30 04-10-2006 12:22 PM
2005 Bambi Sewer Connection DreamStream 2005 and newer - Bambi all models 2 03-03-2005 09:53 AM
