Old 11-17-2006, 08:46 AM   #1
kamo's Avatar
burbank , California
sealing holes and around pipes
Hello,
What material should I use as a seal around the areas where pipes go through the floor e.g. waste pipe, gas lines etc...
There was this sticky black tar-like material used originally, but I'm not sure what that was. Basically I need something that compatible with rubber grommets and plastic and copper pipes, and easy to remove.
Any suggestions?
Kamo
kamo is offline   Reply With Quote
Old 11-17-2006, 10:23 AM   #2
Images: 59
On the inside, I use the same sealing tape that is used on door flanges and window frames. I comes 3/4" wide in 30 ft rolls at any RV place.
I usually end up in a "do-over" when mounting doors, so I wad up the previously used putty and stick it around the pipe.
On the outside, buy a Oatey "No Caulk Roof Vent Cover" from your local Home Depot. I cut about 3" squares, drill a hole in the center, and rivet it to the outside. Here's a picture of the vent cover and the installed flange.
ID:	28717   Click image for larger version
