Old 01-09-2018, 11:38 AM   #1
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Sanitizing / Draining Fresh Tank
Sanitizing my fresh water tank, and per the pic, there are 2 petcocks (this is a 23D). Water draining out of the petcock on the side of the tank. What is the petcock on the bottom of the tank? Nothing comes out when I open it, and it would sure drain the tank a lot faster!
banderabob is offline   Reply With Quote
Old 01-09-2018, 12:25 PM   #2
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Should be low point drain for the plumbing lines inside. Strange that it'd be empty without you otherwise draining/flushing lines, but maybe it's not that strange and I'm just inexperienced!
If you open a sink valve inside, the fresh tank might speed up just a tiny bit. Altogether a slow drain, though.
Dave
DaveMc is offline   Reply With Quote
Old 01-09-2018, 02:52 PM   #3
banderabob's Avatar
2008 19' Bambi
Bandera , Texas
Dave
Thanks, Dave, I figured it out after reading a note I left myself on the counter after draining the lines back in November. But, they really do need to put a larger drain valve on the tank!!
Sanitizing Fresh Water Dalwyn Sprinter and B-van Forum 18 07-30-2017 07:30 AM
Sanitizing Potable Water tank pond Winterizing, Storage, Carports & Covers 20 04-30-2015 09:17 PM
Sanitizing fresh water systems Lumatic Fresh Water Systems 7 04-30-2015 04:02 PM
Sanitizing Fresh Water, Making a Bomb? HeadWest Fresh Water Systems 11 06-25-2013 12:07 PM
Draining Fresh Water Tank psundstrom Fresh Water Systems 2 10-15-2007 08:37 PM
