Old 04-07-2016, 12:04 PM   #29
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by CoolCat View Post
Thanks, y'all!!
Probably more than you ever wanted to know on the subject!
Bob Martel
WBCCI# 5766
Old 04-07-2016, 02:47 PM   #30
belen , New Mexico
scott tissue in the house and the RV never an issue in 20 years!
alantbird is offline   Reply With Quote
Old 04-07-2016, 05:13 PM   #31
1996 25' Excella
Tillsonburg , Ontario
I just use what we have at home...never had a problem; even without agitation from travel. Some of the issue is what you use for odour control. Some enzyme products also breakdown paper, and are advertised as such. I stopped using formaldehyde products several years ago. Trailer doesn't smell like toilet treatment anymore either.
JCW
JCWDCW is offline   Reply With Quote
Old 04-07-2016, 06:13 PM   #32
Chelsea , Michigan
Images: 12
As a point of information for anyone who may not be aware, formaldehyde waste tank treatment products are generally (perhaps even always) illegal to use anymore.
Bob Martel
WBCCI# 5766
Old 04-07-2016, 10:18 PM   #33
2007 22' International CCD
I use a sewer solution system--works like a macerater pump without the mechanical parts. Chunks of TP get shredded and go right out the hose with the water jet set to pump out.
KE4GNK/AE
Old 04-08-2016, 03:30 PM   #34
2014 23' FB Flying Cloud
1998 34' Excella 1000
Apache Junction , Arizona
Originally Posted by sallye View Post
We have a totally different solution to this "problem." Our solution is a battery operated stainless steel (so it matches our AS!) wastebasket that we keep in the bathroom. When you wave your hand over it, the cover opens - which is what the battery / sensor is for.
We simply drop all toilet paper into the wastebasket, with a plastic liner of course, that so no paper at all goes into our tank. When it gets full, we just dispose of it and add a new liner. Easy.
And the answer to your next question is "NO." Things only smell when there is water present, which there isn't in the wastebasket. The antomatic lid helps also.
We owned a summer house for 30 or so years, and it had an "ify" septic tank and field. We started doing this because of that, and it worked so well for 30 years that we never had to pump it out. We tried once, but there was not enough in there to pump. It sort of tells you how much of a problem TP is to begin with. . . . .
Anyway, we buy any old TP and never worry about it.
Thought we were the only ones doing this. Have been since the late '70s and quite satisfied with the process. So's our black water tanks.
donm168 is offline   Reply With Quote
Old 04-08-2016, 05:35 PM   #35
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Forum members obsess over tow vehicles and hitches, citing safety issues. OK, I get that. But I think the biggest obsession is the black tank. How to make it spotlessly clean only to use again in an hour; which toilet paper to use; which, if any, additive to use....
It's not rocket science- use it, dump it, repeat.
2012 Dodge Durango Hemi/AWD
Old 04-08-2016, 06:30 PM   #36
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
I have been thinking about this thread and you got it on the nose. Seriously folks, it's called a black tank for a reason.
As far as the # of plies, and how soon it breaks down. What kind do you use at home? Use it on the road, after all it's going to get dumped pretty quick unless you really like to hang on to the stuff.
We haven't had a problem in 20 years with stuck or blocked valves on the black tank. Probably because we use and dump when it's full.
Sheesh!
gandttimes is offline   Reply With Quote
Old 05-10-2016, 12:58 PM   #37
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
In amongst all the chatter about which TP to use, let me throw my 2 cents worth in.
I'm using Costco's "Kirkland" brand; which seems to work just fine.
I tested it with the 'water/shake test, and it broke down within a couple of minutes, so I'm using it. No problems yet.
MelGoddard is offline   Reply With Quote
Old 10-18-2017, 11:49 AM   #38
2016 26' Flying Cloud
2011 25' FB Flying Cloud
reno , Nevada
Has anyone used the Costco brand toilet paper? It also states "Septic Safe" on the package.
jomondnv is offline   Reply With Quote
Old 10-18-2017, 01:43 PM   #39
Charmin Ultra Soft two ply, just like we use at home. Seems to be cheap enough bought in bulk from Sam's Club or Costco, and it has passed the water/dissolve test with flying colors.
"RV Toilet Paper" seems to be a niche product, but unnecessary. Its pretty much available at any Walmart store if you want to use it, but as I recall, it does not dissolve as easy as Charmin Ultra Soft...and as pointed out, it's not that cheap.
KE4GNK/AE
Old 10-18-2017, 01:46 PM   #40
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I suppose I ought to try putting Charmin Ultra Soft through my Interstate's macerator pump and see if it jams up the works. But just in case it does clog up the pump, the black tank will be full of clean water, and the Charmin will be clean and unused…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-18-2017, 03:51 PM   #41
2017 27' Flying Cloud
London , Ontario
We use only Costco TP since most of the brands you mention are not available in Canada. We use plenty of water in our black tank, and we always keep the tank 20% full after we dump/flush so water can slosh around. I also like the 1/4 c Dawn in the tank to reduce surface tension and break things up as we move. We have not had a problem.
Philip Jones is offline   Reply With Quote
Old 10-18-2017, 03:51 PM   #42
Mollysdad's Avatar
There's a YouTube video testing toilet paper for RV's
The winner was Charmon Ultra Soft. It beat the Camco RV paper.
I have some Scott RV paper that I'll use up before going to the Charmin.
Gun/Valuables Safe - What safe is the best? BrandonJenna General Interior Topics 22 02-21-2013 12:24 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Septic system hookup rfield54 Waste Systems, Tanks & Totes 3 09-04-2006 07:48 PM
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 3 09-26-2003 06:31 PM
