Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 10-22-2017, 04:53 AM   #81
Sag Harbor , New York
Another culprit is Kleenex facial tissues [or any other brand]. People often think they are light and fluffy, so will dissolve easily, but that is not the case. Ask a plumber about sewer piping clogs, and they are often from facial tissues getting hung up in old waste piping. This form of "paper" is fabricated not to tear when wet. Guessing, Wayne, that your Bounty test will disclose a similar toughness to the paper towel which brags about not falling apart when wet.
Old 10-22-2017, 10:35 AM   #82
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Thanks, I had seen that video before but forgot the results!
I therefore sit corrected.
I will buy and water-jar-test some Charmin ultra-soft to verify the recipe hasn’t changed since the video. I despise the brown-fingers TP that passes for RV-safe, and would vastly prefer to use almost anything else.
Originally Posted by Troutboy View Post
...Here’s an entertaining test video
Old 10-22-2017, 12:08 PM   #83
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Haha, brown finger.....
We use the charmin ultra soft, big pack from Costco..... no issues with the black tank the entire camping year....
Troutboy
Troutboy is offline   Reply With Quote
Old 10-23-2017, 03:39 AM   #84
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Originally Posted by WayneG View Post
For Chits & Giggles I did that test on my Home TP, Scott 1000 sheet, (Otherwise known as 400 grit sandpaper)
The Scott stuff was mostly dissolved after an hour, at least good enough for the RV tank, so I will switch to it for RV use.
I am also testing Bounty 2ply paper towels and after a hour there is no signs of breaking down. I will let it go longer to if anything happens (at least until I get the evil eye from the other half)
One day later and the bounty towel is still intact. I took it out of the jar wrung it out and used it to clean up a coffee spill on the counter.
It tells me than the bounty towels are great for what they are intended, just dont expect them to dissolve in a black tank
WayneG is offline   Reply With Quote
Old 10-23-2017, 04:18 AM   #85
Originally Posted by OTRA15 View Post
. . . Guessing, Wayne, that your Bounty test will disclose a similar toughness to the paper towel which brags about not falling apart when wet.
Thanks for the confirmation.
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 5 06-02-2021 07:13 PM
Gun/Valuables Safe - What safe is the best? BrandonJenna General Interior Topics 22 02-21-2013 12:24 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Septic system hookup rfield54 Waste Systems, Tanks & Totes 3 09-04-2006 07:48 PM
