Old 04-20-2015, 11:43 AM   #1
Prospect , Kentucky
Retrofitting tanks on a vintage 1957 Wanderer
I am doing a shell off restoration/renovation on a 1957 Wanderer Custom. I have taken the shell and subfloor off, and have sandblaster the trailer and applied POR15 to the trailer. I want to purchase a new fresh water tank, gray water, and black water tank. I am having a hard time figuring out where and what size inlet and outlet openings to install. Does anyone have any suggestions. The black tank is the 8 gallon, and the gray tank is 16 gallon, 50 x 21 x 4. The fresh water tank would be 40 x 12 x 10 and would fit where the old metal tank was under the gaucho couch in the front. It has an angled fill valve on the exterior of the Wanderer, about 1/3 of the way up the front curb-side panel.
Having never done anything like this, I am in way over my head! If anyone knows of someone who works on vintage Airstreams in my area (LaGrange, KY) I would love to hire someone to show me the ropes, or do the work and let me watch and learn. Thanks in advance for ANY help!
barbaralyn is offline   Reply With Quote
Old 04-20-2015, 12:00 PM   #2
1955 22' Safari
Laredo , Texas
On mine I used 1.5 inch for vents, fills and drains on all but the black tank, which has a 3 inch drain.
55AS is offline   Reply With Quote
Old 04-20-2015, 12:30 PM   #3
Prospect , Kentucky
Thank you BambiTex. Greatly appreciated! Do you know offhand where you had the drains and vents installed on the tanks?
Old 04-20-2015, 12:34 PM   #4
1955 22' Safari
Laredo , Texas
I bought my tanks from VTS (Vintage Trailer Supply) and had them install all the fittings. They will put them wherever you like for a small fee.
Retrofitting Old Propane Tanks (non-opd) leslie LP Gas, Piping, Tanks & Regulators 21 10-31-2018 07:03 PM
Lucky 13 :: 1957 Airstream Wanderer Lucky 13 Airstream Registry Discussions 0 08-19-2011 08:31 AM
` Vintage ` 1957 18 ft airstream wanderer eBay Watch Airstreams on eBay 3 03-27-2010 08:00 AM
new member - 1957 Wanderer rapinw Member Introductions 5 11-27-2006 12:40 AM
Retrofitting Roof A/C 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-14-2003 04:54 PM
