Old 04-12-2004, 06:00 PM   #1
srgntpepper's Avatar
Lightbulb Replumbing '63 Safari
Hello all I am back after winter here in western Pa, Time to finish up the Safari and get ready for the maiden voyage (april 30th), My question is I am replacing all the plumbing in the trailer and I was wondering what type of pressure regulator was used for city water hook-up? I am quite competant in plumbing so it will be no problem, also does anyone have any suggestions for running the plumbing around the rear of the toilet on the radius, I was thinking of using cpvc, but was wondering what toher people have used in this area? Thanks Srgntpepper
srgntpepper is offline   Reply With Quote
Old 04-12-2004, 06:16 PM   #2
Cruiser's Avatar
1952 25' Cruiser
Dummerston , Vermont
Images: 45
Originally Posted by srgntpepper
...does anyone have any suggestions for running the plumbing around the rear of the toilet on the radius...
Our '52 was plumbed with copper, much of it burst or leaking. We're replacing it with Pex tubing 'cause it's forgiving: flexible, easy to connect, and less prone (we hope) to damage from movement of the trailer. Pex tubing comes in rolls, so I'd think it'd run great around a radius.
Don't know much about pressure regulators; just picked one up at the RV store that said it was for city water inlet. Hope to find out in this thread if I got the right thing!
Doug
Cruiser is offline   Reply With Quote
Old 04-12-2004, 07:11 PM   #3
Thanks alot Doug
Old 04-13-2004, 07:38 AM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
When it came time to replumb my TradeWind, I decided to use Pex for a number of reasons. I liked that it is flexible, uses quick connections and it is suppose to hold up to freezing temperatures better than copper. I've had it in now for over two years and have had only one small leak, which just required tightening the elbow connection to fix. I wrapped the hot water lines with that foam insulation with the slot in it and it keeps the hot water very hot all the way to the tub. It follows the shape of the curve in the bathroom wall very well. You won't regret using Pex if you do it right.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-13-2004, 08:32 AM   #5
1989 34.5' Airstream 345
Silverton , Colorado
Sorry to be so dumb, but what is Pex?
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 04-13-2004, 09:08 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
That's ok. we know you can't help it.
(kidding, of course!!
"Pex" is "cross-linked polyethylene". its a plastic tubing used for water pipes. most new RVs are plumbed with it, as it holds up better to freezing temps than copper, its somewhat flexible, depending on what type you get. (some doesn't bend well at all), and its easy to install. it uses special compression type fittings.
here's a site w/ tons of info: http://www.pexconnection.com/
here's an installation guide for the "flair-it" type, which appears to me to be the type to use: http://www.pexconnection.com/instlltnguide.pdf
they sell the "qest pex" and associated fittings at Lowe's...dont' like the looks of it, particularly. the packages for the fittings warn agains using it in enclosed walls. I can only assume that's because they are prone to leaks.
the other type (probably used mostly by professionals) requires special expensive tools for connecting crimp rings to secure the pipes to the fittings.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-13-2004, 10:58 AM   #7
Thanks, Chuck!
Michael & Tracy
1989 345 Motorhome
Old 04-13-2004, 12:59 PM   #8
If I recall correctly, the PEX on rolls can take a radius four times the pipe diameter when bent in the direction of the roll. The straight PEX can take a radius 10 times the diameter. Don't take this as gospel, but I think that is right.
When Quest says not to use it in enclosed walls they are talking about behind drywall or other material where it is not accessible. No plumbing connections other than soldered copper are, to my knowledge, permitted behind enlcosed walls by building codes. An Airstream has no enclosed walls in this context.
Mark
Old 04-18-2004, 11:40 AM   #9
Over59's Avatar
Putnam , Connecticut
Images: 37
I am also gong to use the pex for a complete replumbing. My plumber is coming by when I have everything in place to put on the professional fittings. Worth the money to never have problems on the road.
Can this stuff take a freeze without damage?
Over59 is offline   Reply With Quote
Old 04-18-2004, 01:32 PM   #10
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I don't think any type of plumbing can survive a hard freeze, its just that PEX is a little more forgiving than copper. If you live in a cold climate, be best to winterize properly.
FF
Old 04-18-2004, 05:50 PM   #11
Originally Posted by psychpw
I am also gong to use the pex for a complete replumbing... Can this stuff take a freeze without damage?
The tubing can almost certainly take repeated freezings without spliting. The connectors almost certainly cannot.
Mark
Old 04-18-2004, 06:14 PM   #12
Over59's Avatar
Images: 37
Always something.
Safari :: 1996 Airstream Safari Land Yacht tlw12 Airstream Registry Discussions 0 12-18-2011 08:47 AM
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 11:30 AM
