Join Airstream Forums Today
Old 11-05-2011, 09:23 PM   #1
1993 25' Excella
Wenatchee , Washington
Replacing old platform toilet with "regular" toilet?
In the remo of our 1993 Excella 25' I find the bathroom so tiny and I hate the toilet that is mounted on that kooky platform. Husband says the platform stays because of the flange that is part of the black water tank. It comes out at an angle and evidently will not accommodate a toilet which is tall enough without the platform due to clearance issues (whatever!).
Can you modify the tank to accept a regular toilet? Anyone try this already?
Is the platform toilet my fate?
Sharon
Mrs.S is offline   Reply With Quote
Old 11-05-2011, 10:47 PM   #2
1971 18' Caravel
1974 Argosy 20
1975 Argosy 22 Rear Door
Kooskia , Idaho
In all the Airstreams and Argosy's I have had with the short "Platform" toilet, the black water tank is/was directly under the toilet and that put the black water tank above the floor. Without major renovations of where the tanks are placed, and all the plumbing associated with the draining of them, I would speculate that you are simply stuck with that platform configuration. Sorry.
Old 11-21-2011, 09:06 AM   #3
dcm
bloomington , Minnesota
where can a person buy such a toilet ?
dcm is offline   Reply With Quote
Old 11-21-2011, 12:57 PM   #4
The platform is why Thetford makes a low profile Galaxie toilet. I couldn't stand the crummy plastic toilet and put a regular Thetford toilet in my 25 ft. Safari with a platform. I am 6'6" and only my toes touch. My wife is shorter and her feet dangle. Which is worse, dangling feet or a crummy plastic John?
handn is offline   Reply With Quote
Old 11-21-2011, 03:52 PM   #5
Alumaholic's Avatar
Albuquerque , New Mexico
You don't have a "platform toilet" you have a "low profile toilet" sitting on top of your black water holding tank.It is designed that way. Your bathroom is literally built on top and around your holding tank.
Ken
2007Chevy 2500 HD Duramax/Allison
NM Unit WBCCI #8654, Affiliate Four Corners Unit
"Those Airstream photos on the internet that fuel your fantasies will always capture the gleam of aluminum, but rarely all the blemishes, and never the smell."
Alumaholic is offline   Reply With Quote
I want a new toilet. ROBERTSUNRUS Sinks, Showers & Toilets 4 08-25-2011 08:14 AM
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
How do I find the correct replacement toilet? meredith Sinks, Showers & Toilets 1 07-15-2011 12:20 AM
Toilet height- too high? SalandViv Sinks, Showers & Toilets 5 05-08-2011 11:06 AM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
