Old 04-14-2010, 01:49 PM   #15
1977 Argosy 24
Milltown , Wisconsin
Originally Posted by mimiandrews View Post
We replumbed our Safari with Pex a couple of years ago, and it works great. We used the crimp fittings.
One thing that proved really, really necessary was planning. Draw a rough schematic of the old system before you start cutting. Plan ahead carefully so the last place you have to join Pex to fittings is located where the crimping tool has room to operate. You can usually measure and pre-assemble the parts that go where the crimp tool cannot. Install the lines as an assembly and make that last joint out in an open area.
Good luck.
Now that is good advice!
ventport is offline   Reply With Quote
Old 04-14-2010, 02:47 PM   #16
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
This is interesting. I replaced all the faucets in our '64 with some groovy Zurn products, and hooking up the copper was a pain. I used compression fittings, more expensive but easier to do in tight quarters than sweat soldering, and no chance of catching the fiberglass bathroom alight. I've entirely re-plumbed not one but two vintage 1907 homes myself with copper, and switching to Pex sounds better and better.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-14-2010, 05:04 PM   #17
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Go on Ebay search for compact crimper,under $40.00 ,you will save that much on a small job.
Dave
easyride is offline   Reply With Quote
Old 04-14-2010, 08:15 PM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
All fittings required.
www.iplumb.tv has all the different fittings "Flair It" for every application. Even those that connect directly to the sink faucets or for the flexible lines used to connect a sink faucet. Those with standard pipe thread as well.
I don't sell the stuff, I just like it.
TG Twinkie is online now   Reply With Quote
Old 04-17-2010, 09:08 PM   #19
1971 27' Overlander
Edmond , Oklahoma
Sorry all for the late response, and thanks for all of your input. While I am sure that I could handle the job myself, I am pressured by two kids in diapers, and too many other projects (including a 1964 Cadillac DeVille Convertible) that are in line before the airstream. I committed that I would not let things linger on the Airstream, because we are really wanting to get started taking the kids on trips, so I will more than likely have someone do the job for me.
From what I have been told is that b/c the pipes have all been frozen over and over for many years that the whole shooting match needs to be replaced. I am taking it to another guy on Monday, and will have him convince me of this fact prior to having any work done.
Thanks again all. Happy Trails,
JBB
jbrownokc is offline   Reply With Quote
Old 09-22-2010, 06:27 PM   #20
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
great thread ..I am going to give up on the old copper in my 66. I fixed one leak and found two more. Before I flood out the floor again, I will look in to the PEX redo. Never done much plumbing so it will be interesting to say the least.
Any ideas on about how much tubing to get?
What is the best way to estimate, just measure as much as I can see of the copper? Also I assume 1/2" is what I would use.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 09-22-2010, 06:42 PM   #21
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Greetings from the other side of the OKC metro area -- we're in the same boat, although I'll end up doing it myself at somepoint. So far in our Overlander, I've had two copper lines bust in the middle of the pipe (requiring me to patch), and I've had to re-sweat almost all of the lines under the galley. The PO used garden hoses all over the place, so eventually we're going to PEX it all as well. PM and let me know who you're using, as I'd be interested in the quote.
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 09-22-2010, 06:58 PM   #22
davenpow's Avatar
1975 31' Sovereign
Canby , Oregon
I have replace all the copper pipe in two different 31 footers, center bath and rear bath.
Bought a roll (50') of red and blue, and used Watts Quick-Connect fittings. It was a lot easier putting in the PEX for the first time than it was taking out the copper. By the way with Watts system no crimp tool needed.
Good Luck on your projects.
ted
davenpow is offline   Reply With Quote
Old 09-22-2010, 07:38 PM   #23
Splitrock's Avatar
Sioux Falls , South Dakota
ted
Are those connections removable? The crimp plan sounds hard to disconnect. It seems with wires and plumbing I'm always changing stuff. Some crimp would be fine. I'd just like some connections removable.
Gary
Old 09-22-2010, 08:07 PM   #24
BossCamper's Avatar
1973 25' Tradewind
Chatham , Ontario
Gary
Yes, they're removable, and really easy to use. You can even mix and match your pipe material (you can join copper to pex, ect.). I just did all the plumbing in my '73 Tradewind but I used all crimp because of the price difference.
Each crimp joint costs pennies ... each Watts type joints costs dollars!
Airstream Project Picture Gallery
http://lorisart.org/gallery/thumbnails.php?album=34
BossCamper is offline   Reply With Quote
Old 09-22-2010, 09:07 PM   #25
Splitrock's Avatar
Thanks BossCamper,
That sounds good. If I buy one crimp tool, what size pex pipe makes sense?
Gary
Old 09-22-2010, 09:34 PM   #26
BossCamper's Avatar
1973 25' Tradewind
Chatham , Ontario
I used all half inch.
I got lucky, and maybe you can too. The place I got the pex from rents the crimp tool for $5.00 a day. Look into tool rental places around you. You may find you can rent them quite cheaply. I simply put everything together un-crimped, then went and rented the tool and crimped everything. Probaly only took an hour or two to crimp.
One point to keep in mind, that I didn't know until I actually started crimping is that after you crimp the joint, you can swivel the elbow, or whatever, on the pipe unlike when you solder copper. It may sound like a minor point, but to me it was huge! It meant I didn't have to be perfect with the angle of the elbows before I crimped. If I was off a bit, I just turned the elbow in the crimped joint to line up with the next fitting.
It's true, you need to plan ahead as you crimp to do any recessed joints out on the floor and then put them in place with your final joint out where you can get at it.
There are also different tools out there. Some that need to have the handles open very wide to get on the crimp ring. The one I rented was maybe twice the size of a pair of vice grips, and the jaws opened in a sort of two stage action, meaning the handles only opened about the same as a pair of vice grips, meaning I could get into smaller areas to crimp.
Good luck, and have fun!
Oh yeah ... when I was done, I only had two leaks and those were where I hadn't gotten on the crimp ring fully, and only compressed the edge of the ring. This system works really well if you're careful and get the pex fully onto the fitting and crimp properly.
Loris
Old 09-22-2010, 09:40 PM   #27
Splitrock's Avatar
BossCamper, Great post! Even answered my leak question before I asked it:-)
Thanks for the help. I appreciate it.
Gary
Ventilation pipes Lothlorian General Repair Forum 8 09-25-2008 04:21 AM
replacing copper water lines purman Fresh Water Systems 6 07-26-2008 11:25 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 09:45 AM
what pipes to use? kamo Fresh Water Systems 3 10-23-2006 03:58 PM
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-27-2004 12:42 AM
