Old 04-14-2011, 02:09 PM   #1
1971 27' Overlander
Seattle , Washington
Replacing all faucets in '71 overlander
I am replacing all copper plumbing with PEX. I need help on how to remove and replace all faucets. Kitchen, bathroom, and shower. Bathroom is tough. Seems as it it is all riveted together. Any ideas?
jesse_kevon is offline   Reply With Quote
Old 04-14-2011, 02:13 PM   #2
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
I haven't replaced mine, but I had to replace the copper going to the shower as well as the bathroom sink. I can tell you that I just about had to remove the upper parts of the bathroom module just to gain access to the plumbing (especially the shower). If you take off the plastic molding off and drill out all of the rivets, you can basically take off the top unit.
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 04-14-2011, 02:13 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Are you replacing the faucets just because you want new ones? Or because you think you must for the PEX?
If your '71 is set up like my '75 rear bath, replacing the shower valves will be a big project. Then the PO of my trailer put in PEX, he left the copper running from the shower into the vanity, and tied into the PEX there.
— David
Old 04-14-2011, 02:21 PM   #4
1971 27' Overlander
Copper pipes busted throughout the entire trailer. Bathroom and all, so I am just going to use PEX throughout. Shawn, those pictures help alot! I was afraid I was going to have to drill out the rivets to get access. But, there is no other way around it it seems. Did you replace your kitchen sink as well? When Looking at mine, it seems the pipes are soldered on to the bottom of the faucet. Meaning I would have to cut the copper just to take out the faucet.
Old 04-14-2011, 02:55 PM   #5
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I didn't even have to cut the lines. Mine burst so much, they were completely unhooked. I would recommend pulling the kitchen sink though as that's the easiest way to remove and replace the faucet, and any fittings you need to add for putting the pex in.
I'm doing the same entire job. ug. I ordered a new delta faucet that is the exact same as the original. I'll find out today if the new "old styles" use a different supply configuration. It should have come in the mail today.
robwok is offline   Reply With Quote
Old 04-14-2011, 03:08 PM   #6
Addicted
exthemius's Avatar
1971 27' Overlander
Images: 16
We didn't replace any of the fixtures, but yes, all of the fixtures were sweated on, so there's really no easy way to replacement except to cut'em out. Luckily, we were forced to gut everything under our galley, so gaining access to that plumbing was pretty straight forward (unlike the bathroom).
-Shawn
TAC OK-42
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
Replacing windows in 1967 Overlander MAbdala Windows & Screens 12 05-15-2015 05:46 PM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Need Refrigerator Compartment Door for 1972 Overlander jazz1945 Exterior Storage Compartments & Access Doors 1 05-30-2011 02:50 PM
Overlander Gaucho pics NicheVintage 1965 Overlander 11 01-28-2011 12:12 PM
