Old 03-13-2016, 12:16 PM   #1
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 53
Replaced leaking pump
We finally discovered the source of our slow water leak - the underside of the front of the Aquajet pump - original pump 13 years old. It was a slow drip right at one of the pump head screws. Water was coming out on floor at wall by shower.
Purchased a Shurflo 4008-101-E65 3.0 Revolution Water Pump ($65), Shurflo 182-200 Pre-Pressurized Accumulator Tank ($42), Shurflo (255-313) 1/2" Twist-On Pipe Strainer ($7), and Shurflo (94-591-01) Pump Silencing Kit ($26), all via Amazon. Removed old pump (10 minutes), and installed replacement system in same area (20 minutes). Used teflon tape on each plumbing connection. All plumbing connections matched. Installed Disconnects (0.25 tab, 16-14) from Home Depot in DC lines to pump.
Have no leaks. New pump system is very quiet. Pleased with water flow rate (old 3.5 gpm, new 3.0 gpm). Simple project, great results, good prices.
ID:	258686   Click image for larger version
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Leaking Water Pump Adam Geuss General Repair Forum 3 06-17-2015 04:04 PM
Water pump leaking - 2006 Classic mkdaily3 Water Heaters, Filters & Pumps 3 08-01-2014 05:45 PM
Water pump leaking - repair or buy new? Doug C Water Heaters, Filters & Pumps 2 04-29-2014 07:49 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
