Old 05-03-2006, 04:51 AM   #1
replace water drain valve
My old water drain valve is shot. Where is best place to get a new one? Is there something I can replace it with that is EASIER to use? Anything complicated about installation other than some sealant and a couple screws? Thanks.
Anniedog is offline   Reply With Quote
Old 05-03-2006, 09:22 AM   #2
surferstyler's Avatar
1972 27' Overlander
San Juan Capistrano , California
I used Pex, and thought it was very easy to use. See my thread for pictures.
Ron
http://www.airforums.com/forum...der-21030.html
surferstyler is offline   Reply With Quote
Old 05-03-2006, 11:28 AM   #3
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Well, I don't know what vintage you have, so I can only tell you what I did with my frozen valve: Replace it with a more modern one that i got at the hardware store. I had to sweat soldered it in, first time I had ever done that. That required pulling the water assemlbly off of the tank. What is your configuration? Can you take a picture?
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 05-03-2006, 06:27 PM   #4
Water drain valve replacement 1988 Excella 1000 29'
Okay, let me be more clear. I want to replace the small plastic (nylon) drain valve that is between the wheels on the roadside of my trailer. It drains my freshwater tank. It has always been an annoyance and now it is about to break. I need advice from someone who has perhaps done this little job. And it would be of great assistance if someone could point me toward a supplier. Thanks much.
The trailer is a 29' 1988 Excella 1000.
Old 05-03-2006, 07:16 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
annie
this is how i repaired mine...
http://www.airforums.com/forum...pair-5206.html
john
you call them ferrets, i call them weasels.
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
