| Removing & Replacing Shower Drain
Greetings Ken!
Something else to consider is that your drain traps may be being blown dry when traveling on the highway. My Overlander periodically had the problem that you describe, and it finally dawned on me that the water that was always present when I removed the terminator cap -- was the water from my drain traps. Now, whenever I return from a trip and park the coach, I make sure to pour a cup of water down each drain to fill the traps. If the coach isn't used often enough to keep the water replenished in the traps, some RV antifreeze might be less likely to evaporate.
Good luck in locating your problem.
Kevin
P.S.: Have you checked/replaced the waste tank vent seals on the roof of your coach? If these gaskets have failed, the opening would provide a route for sewer gasses to enter your coach.
Kevin D. Allen WBCCI (Lifetime Member)/VAC/Free Wheelers #6359 AIR #827
