Old 08-04-2012, 05:00 PM   #1
1973 25' Tradewind
Santa Rosa , California
Relief valve.... not hot water heater
This is my first post. Just purchased beautiful 73 Tradewind and am in the process of refurbishing it. There is a relief valve which ties the end of the hot piping into the cold piping just after the pressure regulting valve. Trying to figure out why it is here, and what is its sequence of operation.
On interntional model, it relieves thru floor.
I'd be grateful if anyone caan help me with this.
Thank You
Smitty Smith......Marcus's pal and plumber
Enid is offline   Reply With Quote
Old 08-04-2012, 06:06 PM   #2
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Please post a photo, I can't quite picture what you are describing.
And welcome to the forums!
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 08-04-2012, 07:23 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There should be a relief valve after the regulator on the city water supply line. The water should exit the trailer via a pipe through the floor if the relief valve is activated by excess pressure.
Richard
Old 08-05-2012, 08:13 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Odd place for a relief valve (usually it's on the heater itself), but all hot water systems should have relief valves. If the water heater malfunctions and gets hot enough to boil, pressure builds up VERY fast from trapped steam, and that pressure has to go somewhere.
Given the location, are you sure it's a relief valve and not a low point drain?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-05-2012, 08:21 PM   #5
Protaganist, sounds like you might be on to something there, probably a low point drain. Sure could use a photo.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 08-17-2012, 04:49 PM   #6
tfbeitz's Avatar
1979 31' Excella 500
1973 25' Tradewind
Cinnaminson , New Jersey
Presure relief
The PO of my Exella really had some of the plumbing messed up.
The City water and the water from the fresh tank were joined via a T to go to the pressure regulator. from there it went to the pressure relief that was plugged.
All of the lines were a mix of "PolyButyl"/PB ?, white reinforced hose, green hose, black hose.
Im going to replace most with 1/2 PEX and join to 3/8 PB to the unaccessable areas
I too am having problems with understanding the Pressure relief. Does the top of the valve blow, I would think that there are other connections that would blow before the 60# relief valve.
Another question I have is that, the regulator and the back flow valves have a "reside" on the inside. A brownish discoloration.
Is there anything to help clean out these fittings, Soak them in a solution of ???
Tom Beitz
6760 PA Unit
TAC NJ-5
Riverton, NJ
tfbeitz is offline   Reply With Quote
Old 08-24-2012, 02:00 PM   #7
rogerdodger's Avatar
Fresno/Clovis , California
My Argosy also had a pressure relief valve directly after the pressure valve, and it vented thru the floor. I am sure this was original. I took out the pressure valve, relief valve, and all old copper. I am not going to replace those valves, it seems unneccessary, because I always use a pressure valve at the water inlet at RV parks. This is not the hot water pressure relief valve on the hot water heater, that one is required for safety if the water heater malfuctions.
Also, by using pex, the pressure rating is 160 lbs at 73f, so 50 lbs at the RV inlet will not require an internal pressure relief valve, IMHO.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 08-24-2012, 02:02 PM   #8
If you need to clean out the valves, use CLR, it works great, I used it on my backflow valve, which is all brass.
Roger
Air# 29488
Old 08-24-2012, 04:22 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Actually since there is supposed to be a check valve to keep water from going back out of the trailer it is a closed system so when the water heater heats the water it increases the pressure in the entire system not just the hot side.
Old 08-24-2012, 07:16 PM   #10
I,m no plumber, but have owned several (nine) sob's and none of them had a pressure relief valve anywhere in the cold water system, but they all had a backflow valve, to prevent water flow out the inlet when using water pump.(closed system). The AS is the first, and I don't think it is necessary. IMHO
Roger
Air# 29488
Old 08-24-2012, 07:32 PM   #11
1988 32' Excella
It is one of the recommended solutions (by Atwood) with their new higher temp water heaters that come in new Airstreams. I agree though it is probably not needed with other water heaters.
Old 08-24-2012, 07:45 PM   #12
Which brings up another question; if the higher temp water heaters create a problem, why dont they decrease the pressure relief valve on the WH from 150(standard) to something less as protection?? Why the need for another relief valve? Again, just asking, I'm no expert.
Roger
Air# 29488
Old 08-24-2012, 09:22 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
River; that makes too much sense.
Old 08-25-2012, 05:44 AM   #14
The newer Atwood water heaters have a mixing valve in the system to add cold water at a ratio of 2 hot to 1 cold, even before you get to the mixing valve at the faucet. The heater produces water hot enough to scald otherwise. It's a gimmick to say thay can get nine gallons of hot water out of a six-gallon heater. Since there is that extra mixing valve, if the water heater overheats, you can over-pressure the cold side as well.
WBCCI #1105
TAC LA-4
