11-19-2011, 02:54 PM
2008 19' Bambi
Austin
Red Drain Tube
Hi,
Where does the water that drains from this tube come from?
And, maybe more importantly, WHY would water be coming from it?
Lynn
11-19-2011, 02:58 PM
2008 19' Bambi
Austin
Crisis averted, I think. I found the valve. Now that it's closed, no more draining water.
11-19-2011, 03:00 PM
Oswego
I think that is your hot and cold water line low point drains. They are for releasing all water for winterizing. Do you have two valves inside and above these hoses? I think your hot water drain valve is leaking.
"All I want in this life of mine..... is some good clean fun" - Little Feat
11-19-2011, 04:28 PM
2007 20' Safari SE
Cuddebackville
, NY
Yup. Red=hot; white=cold.
11-19-2011, 05:50 PM
2008 19' Bambi
Austin
You're right, it was the hot water drain valve. Somehow we had bumped it and it was open.
Thanks!
11-19-2011, 05:59 PM
2006 19' Safari SE
Tucson
Originally Posted by lcurrie
Hi,
Lynn
You figured that one out... I noticed in your picture that here are a couple of brackets holding the other red line in place (the one in the foreground of the picture) have become disconnected...you should find where those were connected and reconnect them so the line is solidly secured...they do get lose from time to time and need to be checked periodically...they are held up with metal screws...
| Thread Tools |
| Display Modes |
