Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 02-03-2009, 04:39 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Real Time help- How to remove this flange?
Anybody know how to remove this metal flange that is below the toilet? Take a look at this pic. I have removed the screws that still show in the picture.
Thanks!
SilverHoot is offline   Reply With Quote
Old 02-03-2009, 04:54 PM   #2
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
I believe there is a tool that does it, however when they get all rusty like that I have found that two sticks of dynamite works best!
FLYNCLD is offline   Reply With Quote
Old 02-03-2009, 04:57 PM   #3
SilverHoot's Avatar
1967 24' Tradewind
Lol
I was afraid of that! Are they threaded on? I'm afraid if I torque on it too hard I'll ruin the tank.
Old 02-03-2009, 05:00 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That looks like a regular toilet flange used in houses. It is probably glued to the ABS plastic pipe from below. If it is, you'd have to cut the pipe and couple new pieces on.
Old 02-03-2009, 05:04 PM   #5
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
A bolt on each side of the flange sticking up about 2 inches. It needs to have threads all the way to the head ,like a carrage bolt.run a nut down on each bolt so they are tight to the flange, then use a long bar layed horizontal to the floor between the 2 vertical bolts. You should now be able to unscrew the flange from the tank. Good luck, this worked on my 67. Adios, john
Diesel1 is offline   Reply With Quote
Old 02-03-2009, 05:20 PM   #6
SilverHoot's Avatar
1967 24' Tradewind
Bigger hammer
Yes, it's threaded and yes it ruined.
Old 02-03-2009, 05:29 PM   #7
FLYNCLD's Avatar
Bend , Oregon
Yea and the dynamite is a lot more fun!
Old 02-03-2009, 05:30 PM   #8
FLYNCLD's Avatar
Bend , Oregon
Actually it looks like the piece did unthread before it broke? IF so you can just replace the flange
Old 02-03-2009, 05:37 PM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
No! No! No!
Too late.
This is a simple job. Make your own spanner wrench by taking a 1 x 2 board about 12 in long. Drill and put a 1/4 in. bolt...about 1 1/2 in long thru it. about 2 in from the end. Drill and put another 1/4 in by 1 1/2 bolt at a point which will put both bolts in a position where they fit into the flange cut outs. Then simply twist the flange off. Lefty loosey...righty tighty.Replace the flange...throw the wrench away.
Old 02-03-2009, 06:06 PM   #10
Wayne&Sam's Avatar
Images: 21
AH, so they attach directly to the tank. I should have realized that- i've never taken one apart.
Old 02-03-2009, 08:28 PM   #11
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
hey you lucked out and had a threaded flange!
when i put a new toilet in my A/S the one i pulled out was glued to the black water tank.
now that was a fun fix with a rubber coupler that didn't really fit right.
osolow is offline   Reply With Quote
Old 02-04-2009, 08:22 AM   #12
SilverHoot's Avatar
1967 24' Tradewind
Well.... thanks everybody I got it off using a chisel and a large hammer, or should I call it a small sledge? Anyway, I made two errors, while removing the acorn type nuts that hold down the toilet to the flange I did not realize that the bolts/studs did not go through the toilet platform. The bolt on one of them just spun as I turned the nut so I ended up cutting the bolt off with a Dremel tool only to find out once I lifted the toilet off that once loosened the toilet could have been rotated and the studs lift out with the toilet. Lesson learned. I'll be removing the black tank today so chime in if there are any tricks!
Old 02-04-2009, 08:54 AM   #13
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Rubber gloves and a mask.
Good luck and take your time. I know its yucky but don't be in a hurry and mess something up permanently. Why are you taking it out? Are you planning on using this tank or getting a new one made?
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 02-04-2009, 08:55 AM   #14
FLYNCLD's Avatar
Bend , Oregon
Well if you end up needing a new black tank, I've got one for sale!
Old 02-04-2009, 09:11 AM   #15
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
SilverHoot, I assume you are removing the toilet and tank as a prep to doing a floor replacement. The key is to take your time!!!!! I cannot stress this enough. Be very careful not to damage the threads on the tank where the flange attaches. Be sure to support the tank before lowering it to the ground as it could still have some material (yuck) still inside! Then remind yourself that you only want to do this once and make your floor repairs and re-install being aware of how tight you try to thread the flange back on the tank. Remember the tank has age and the welds may be brittle. ED
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-04-2009, 12:10 PM   #16
SilverHoot's Avatar
1967 24' Tradewind
flyfshr, I'm taking everything out to replace maybe the entire subfloor. Pics can be seen here Picasa Web Albums - Mike - 1963 Silver S... There is a bad spot in the flooring that runs under the toilet platform so it definitely needs to be removed so I can check on the integrity of the floor under the platform. Don't think it was the toilet that caused the bad flooring, rather the hot water heater next to it. Going out in a few minutes to work a bit more before having to take a break for a few weeks due to surgery this afternoon.
Old 02-04-2009, 12:14 PM   #17
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
SilverHoot - good luck with the floor and a speedy recovery for successful surgery.
All the best,
FF
Old 02-04-2009, 02:09 PM   #18
SilverHoot's Avatar
1967 24' Tradewind
OK, I removed the black tank after cutting the gray drains away from the valve and pulled it all up through the inside. Is it usual to have this LARGE a hole in the floor? Remember I'm a complete newbie to trailers but I am seriously doubting that this trailer came from the factory with with the frame cut away to accommodate plumbing! have a gander...
ID:	75061   Click image for larger version
Old 02-05-2009, 09:54 AM   #19
Dan@LED4RV's Avatar
Denton , North Carolina
would this help?
Thanks!
When going back with your flange, a very common mistake I have seen is people using screws that are tooooooo long and end up running the srews into the top of the tank.
Click here to see the flange.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
How to Remove Toilet Flange from Waste Tank? monocoque Waste Systems, Tanks & Totes 15 06-10-2013 06:41 PM
Real Time Mileage Monitor Airstream87 Tow Vehicles 0 06-03-2008 03:42 PM
Real-time A/S Chat John Our Community 3 01-16-2003 06:47 PM
Real Time Chat Sessions! Andy R Our Community 2 08-29-2002 01:25 PM
