Old 02-12-2015, 01:17 PM   #1
Woodland Hills , California
rbi
I have a 2010 Flying Cloud 19'. When I turn on the pump water is flowing in the shower even though the valve is closed tight? When I turn off the pump, water drips from shower head for about 4 minutes??? Help please, Thanks.
rbi2000 is offline   Reply With Quote
Old 02-12-2015, 04:03 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
Sounds like the faucet/fixture/valve that controls the water going to the shower head is wide open. When you say the valve is closed tight, is this the valve you are talking about? If so, it has apparently failed. You might be able to disassemble the valve and replace seals/washers/O-rings, or you might have to replace the entire fixture. Can you post a pic of your fixture?
good luck!
